Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 72
Thread: BB Logging beta update: April 07, 2008
  1. #61
    Nov 2006
    when will BEN factor be available with external WBO2?
  2. #62
    It is now.
    Use the attached sae_generic.txt file.
    The PIDs are called:
    CALC.BEN1 "BEN Factor Bank 1, Serial Wideband, LS1 style"
    CALC.BEN2 "BEN Factor Bank 2, Serial Wideband, LS1 style"
    CALC.BEN1_B "BEN Factor Bank 1, Serial Wideband, LS2 style"
    CALC.BEN2_B "BEN Factor Bank 2, Serial Wideband, LS2 style"
    CALC.BEN1_E38 "BEN Factor Bank 1, Serial Wideband, E38 style"
    CALC.BEN2_E38 "BEN Factor Bank 2, Serial Wideband, E38 style"
    P.S. Thanks to Chad (from GreenLight Motorsports) for setting up the sae_generic file with the correct analog and serial wideband PIDs and BEN factor PIDs for E38.
  3. #63
    Oct 2005
    While transferring logged files to the PC I noticed that the transfer is rather slow.....not sure if it is supposed to be that way but a 1.5Mb file took about 30secs. to transfer.
    2005 RCSB 2500HD GMC Sierra DURAMAX LLY
    1955 Chevy Truck 1st series, being restored
    2002 Mercedes C270 CDI
  4. #64
    Nov 2006
    It is now.
    i selected the PID but see no data in the software.
    it says N/A.
    i also added CALC.BEN1 to the cal.link.txt
  5. #65
    Nov 2006
    this was resolved with a re-boot of the software.
    i am also getting this
    Error code: ERR_PKTSTALL/75
    Starting Dynamic scan mode stalled, please retry.
    when i pause/stop logging/recording
    then attempt to re-start logging/recording.
    persistent attempts to record sometimes overcome this.
    there are times when after selecting my controller (99+LS1)
    it reverts to the V2 as the selected controller.
    also my maps cleared from the map tab and i needed to re-install them.
    i will add that the serial connection for the WBO2 is
    a lot steadier and accurate than the analog connection
    and after connecting (though difficult at times) there
    are no problems keeping connected.
  6. #66
    Lifetime Member hymey's Avatar
    Jan 2008
    Default e38 ben
    # Serial Wide Band BEN factors
    *CLC-00-996
    factor 0.0 2.0 .1 "{EXT.WO2AFR1}/{E38.AFRATIO_DMA}"
    *CLC-00-997
    factor 0.0 2.0 .1 "{EXT.WO2AFR2}/{E38.AFRATIO_DMA}"
    To save reading through. These are the pids for e38 ben.
  7. #67
    Quote Originally Posted by Lennart View Post
    I noticed same.
  8. #68
    I noticed same.
    As did I, in the firmware one or two releases ago, I think, which I posted about.
  9. #69
    Jan 2008
    Its always slow for that size file.
  10. #70
    I just tested the coms on a Vista SP1 machine.
    Copy to FlashScan (SD card) 1.75Mb 21.7 seconds 632 kbps.
    Copy from FlashScan (SD card) 1.75Mb 19.5 seconds 696 kbps.
    Is anyone seeing anything significantly different that this?
    Note: The Trace option in EFILive_Explorer shows the time to transfer and the average transfer speed achieved.
    Also, make sure you have tracing turned off in EFILive_Hapi.exe. On slower computers that can be a time waster during transfers.
  1. BB Logging beta update: April 26, 2008
    Last Post: July 19th, 2008, 04:44 PM
  2. BB Logging beta update: May 19, 2008
    Last Post: June 11th, 2008, 10:22 AM
  3. BB Logging beta update: May 12, 2008
    Last Post: May 27th, 2008, 09:01 AM
  4. BB Logging beta update: May 06, 2008
    Last Post: May 22nd, 2008, 10:57 AM
  5. BB Logging beta update: April 14, 2008
    Last Post: April 23rd, 2008, 08:46 PM
