Page 4 of 11 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 104
Thread: BB Logging beta update: April 14, 2008
  1. #31
    I created a subfolder called "Firmware" and I moved all the firmware files into there.
  2. #32
    Oct 2006
    No, you don't need any of them once a *.efw file is programmed into FlashScan you can delete it. The only reason folks keep them is sometimes during the beta test, I will release a firmware upgrade and it will break some feature. The feature can be restored by going back to the previous *.efw file until a fix is available.
    Thanks , I deleted all of the non essential extensions and re-installed from the zip and all is much learner and neater .
    Config copy worked like it should .
    2006 Trailblazer
  3. #33
    lakingslayer
    Guest
    The PCM TP PID does not work for the LLY so I've been using the PCM TP_A PID. When I load it into the scan tool and try to display the log I don't see the TP_A PID or in the Data tab. I'm also seeing the same issue as with the April 7th release of the data not reading correctly at some frames. I've attached a pic.
  4. #34
    Lifetime Member hymey's Avatar
    Jan 2008
    Blacky I am having the same problem as swingtan. When logging all the pids are showing and recording. I load the logged data to my PC once the scan tool opens all the dma pids are missing from the recording. If I try and add them it wont allow it. It states that the pids can only be selected if I clear the logged data.
    Other than that, all is going smooth. And it flashes very fast with the new calz files. I also noticed in the VVE that thr rpm increments increase by 200rpm all the way whereas before it would increase by 200rpm then 400 rpm further down the column.
    Joel
  5. #35
    swingtan
    Guest
    I have another interesting issue after the last update. When I open a log file now, quite often I get corrupted data in the dash page. This seems to be completely random as the attached image shows. In this image I've opened the same log file twice, the first time it's fine, the second is not.
    Anyone else seen anything like this that may be able to shed some light?
    Simon.
  6. #36
    Aug 2005
    Still seeing the T42 base pressure bug. Screenshots below
  7. #37
    Oct 2006
    Innovate wide-band LC-1 can not be found now , was working fine before latest update now gives me "Controller not Found" message , made sure and selected Innovate in "Options" setup .
    2006 Trailblazer
  8. #38
    Senior Member Hyper99's Avatar
    Oct 2005
    Did you set COM In and COM Out to Wide-02 also?
    99 Silverado 2500 Extracab Longbed
    33" BFG's - American Racing Rims
    Custom Dual Upper console gauge mount w/Autometer Sport Comp - Pyro, Oil Temp
    Autometer Sport Comp Boost/Vac in Custom Hypersonic Gauge Mount in dash
    LS-1 6.0L w/AFR 205cc Street Heads
    Vortech V2 blower
    42# Injectors
    Comp Cam - Custom Street Grind
    TTS Catback Exhaust
    Innovate LC-1 Wideband O2
    Tune and Trans mods via EFILive V1-V2
  9. #39
    Default Print All access violation
    Paul,
    In scantool build 48, doing Print All (button or menu) causes immediate access violation...
    Print single works ok, but it's tedious to generate a report of everything by doing single reports of each tab.
    Joe
Name:	Access Violation - Build 48.png
  10. #40
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    Was able to test Serial for LM-1 and LOVE it. Can't wait for the FJO to be supported. It is simply awsome. Only issue I saw was the values actually went past 20.9 on decel up to 120:1.1 AFR. Made the BEN show 6.0. LOL
  1. BB Logging beta update: April 26, 2008
    Last Post: July 19th, 2008, 04:44 PM
  2. BB Logging beta update: May 19, 2008
    Last Post: June 11th, 2008, 10:22 AM
  3. BB Logging beta update: May 12, 2008
    Last Post: May 27th, 2008, 09:01 AM
  4. BB Logging beta update: May 06, 2008
    Last Post: May 22nd, 2008, 10:57 AM
  5. BB Logging beta update: April 07, 2008
    Last Post: April 14th, 2008, 10:31 AM
