Let's say I have a Log file X and I'm using the "BEN factor-FJO/Autotune" map with my FJO Wideband. I have the "Empty Cell" = 50.Open Loop SD tune.
Now I want to filter :
1.)All noncell 22 data -i.e. All FTC Cell data less than 22 (Open Loop all decel is cell 21 and idle is cell 20).
2.) All TPS transients greater than 5% per 100 msec.
Both filters are setup. Can I do 2 passes of the logged data in sequence - one of each filter ?? Will this reliably filter out all decel, idle and transient data?
joel
