Um, now you need to use the new EFILive Explorer to flash the beta firmware into the V2. You have a V2 with just a bootblock, no firmware so it cant run. Load up EFILive Explorer from the Program Files\EFILive\V8\EFILive_Hapi\EFILive_Explorer.exe and select the firmware tab. Then browse to the same folder and select the file FSProgV2_05_16(0414).efw and flash this. Then your V2 should work.
