Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 104
Thread: BB Logging beta update: April 14, 2008
  1. #51
    Lennart and lakingslayer, the "weird frames or "logs full of notes" sounds like the problem I'm having as well. I've found that repeated tries at opening the file eventually seems to get a clean read and displays "sane" data. I have no idea if the data is actually correct though.
    The way the logs look when they open in "corrupted" form reminds me of the first BBL logs I tried on the E38 when the V2 would cause I/O problems between the ECM and other modules, bringing up dash alerts and dropping corrupted data into the log file. This was back around the start of this year. When opening these files in ScanTool, I'd get the same weir looking data displayed as I get now. It's almost like the BBL files don't have an <EOF> character and ScanTool ends up with random data at the end of the log.
    Simon.
    There appears to be a bug in the frame count value. The frame count value is written into the file as a 16 bit value ("%d") but should be written as a 32 bit value ("%ld"). That will cause problems if the log file is longer than 65535 frames. A fix is being made now.
    If any of you have log files of less than 65535 frames that are showing corrupt frames, please send them to me at [email protected].
  2. #52
    Quote Originally Posted by dc_justin View Post
    Still seeing the T42 base pressure bug. Screenshots below
    Same TCM OS, just a different EFILive release I assume?
  3. #53
    swingtan
    Guest
    I have a few, as I was also finding that opening old log files caused this issue. I just tried opening a log from 24/1/2008 that is 8842 frames long and the first 4 tries resulted in a corrupt display. The fifth try brought up a clean dash page. All I did was to double click the log file and allow ScanTool to open automatically.
    I just noticed that data is stored in the "temporary cache" folder when the files are opened. There are 2 files for each opening of the *.efi log file..
    Corrupt version:
    • efi_cache.0 = 0KB in size
    • efi_filter.0 = 0KB in size
    OK Version:
    • efi_cache.1 = 262KB in size
    • efi_filter.1 = 0KB in size
    The original logfile is 262KB in size......
    Did you still want log examples ?
    Simon
  4. #54
    Aug 2005
    Yep. The same file was opened in both versions of the software. In fact, every 07 T42 file I've opened has had the same problem.
  5. #55
    Lifetime Member hymey's Avatar
    Jan 2008
    Hi Paul,
    I tried some more BBL-ing this morning and while the recording works well, I still can't read any of the DMA PID's in the log file, when loading into scan tool.
    Simon
    Any feedback for this blacky?
  6. #56
    Quote Originally Posted by hymey View Post
    I'm working on it tonight... (no rest for me).
  7. #57
    Quote Originally Posted by Lennart View Post
    DVT is pretty sweet! Turning on/off is a little weird sometimes as the setting will remain on even when shutting off the feature (e.g. idle speed)
    Lennart, the DVT's should disable pretty much instantly, there is also some timers in the ECM that should shut them off if Flashscan is no longer broadcasting the override messages.
    So on your idle speed control, as soon as you untick the idle speed control box the ECM should return to normal operation.
    When you say the idle speed remains in DVT mode, for how long is this for?
  8. #58
    swingtan
    Guest
    I have an update for the PID's issue. I tried pass-through logging this afternoon and noticed that E38.AFRATIO_DMA was reading wrong. It was reading 0.56:1.
    Here's the log file.....
  9. #59
    Blacky I am having the same problem as swingtan. When logging all the pids are showing and recording. I load the logged data to my PC once the scan tool opens all the dma pids are missing from the recording. If I try and add them it wont allow it. It states that the pids can only be selected if I clear the logged data.
    Other than that, all is going smooth. And it flashes very fast with the new calz files. I also noticed in the VVE that thr rpm increments increase by 200rpm all the way whereas before it would increase by 200rpm then 400 rpm further down the column.
    Joel
    The problem was the E38 and E67 DMA PIDs are prefixed with E38 and E67 respectively. Black Box Logging was adding the prefix GM in the *.efi files. When the *.tun files were loaded into the scanner, it could not find (for example) the PID GM.AFRATIO_DMA because the PID is actually called E38.AFRATIO_DMA.
    If you really need the data from those log files, you can edit the *.efi files using Hexedit (from www.bpsoft.com). Change the GM.xxxxxx_M PID names to E38.xxxxxx_M names. In Hexedit that will require you to insert a character after the GM. I.e change the existing "GM" prefix to "E3" and then insert an "8" to make the prefix "E38".
  10. #60
    Paul,
    In scantool build 48, doing Print All (button or menu) causes immediate access violation...
    Print single works ok, but it's tedious to generate a report of everything by doing single reports of each tab.
    Joe
    Hi Joe,
    I still can't reproduce this problem here.
    Can you tell me the settings you have checked in Properties->Printing?
  1. BB Logging beta update: April 26, 2008
    Last Post: July 19th, 2008, 04:44 PM
  2. BB Logging beta update: May 19, 2008
    Last Post: June 11th, 2008, 10:22 AM
  3. BB Logging beta update: May 12, 2008
    Last Post: May 27th, 2008, 09:01 AM
  4. BB Logging beta update: May 06, 2008
    Last Post: May 22nd, 2008, 10:57 AM
  5. BB Logging beta update: April 07, 2008
    Last Post: April 14th, 2008, 10:31 AM
