Page 2 of 14 FirstFirst 123412 ... LastLast
Results 11 to 20 of 133
Thread: What to Tune First
    Jun 2005
    So the VE still kicks in during throttle transitions, which means you'll have to filter these out completely.
    Regardless of whether or not the first part of this statement is accurate, I consider tuning out transitional data in my logs a standard practice....based on the assumption that if you get things working right during the consistent scenarios (between MAF/VE/Injectors), the transitions should fall into place.
    Jan 2005
    Good stuff Jeff. I'll give this a shot with the new build.
    I must be slow.
    If it still kicks in what does setting B0120 to 100rpms do?
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Jan 2008
    Quote Originally Posted by SSpdDmon View Post
    RPM Threshold for Airflow Calc {B0120}: Using your stock, screened MAF, set this threshold to 100rpm to enable a full, MAF-only tune. The purpose of this is to reverse engineer your IFR table based on how the injectors flow in YOUR car.
    Now in the case you're using a set of large injectors right off the bat, I presume this will cause an issue if I were to just toss a fresh base map in there and begin with this approach (w/o regard to IFR), is this correct?
    Dave
    -'07 Acura TL Type-S
    -'07 Honda Ridgeline RTS
    -'00 Pontiac Trans Am WS6
    Aug 2005
    - Throttle Transitions: VE table, regardless of B0120.
    From all of my testing, I would have to disagree and say that once B0120 condition is met, MAF is used exclusively airflow calculation, transient condition or not.
    Justin
    Quote Originally Posted by dc_justin View Post
    Justin
    Oh, it does...? Then I'm wrong, I stand corrected and I edited my post: showpost.php?p=68499&postcount=9
    Justin
    Thanks Justin,
    It would make no sense, otherwise. I'll run some longer scans and see what I can, anyway. I like this idea.
    Joe
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Thanks, I'm going to rerun some of my experiments (zero out VE table and B0120)... ...I'm now sure I goofed up along the way...
    This means that an AutoMAF tune should be very easy...
    Quote Originally Posted by jfpilla View Post
    If engine speed is above this value, then the PCM will use the MAF sensor exclusively (if not disabled by DTCs) to calculate grams of air per cylinder.
    This is the EFI descriptionof B0120. Is it wrong?
    I must be slow.
    Justin
    Thanks Justin,
    Joe
    And my partial-point about transient filtering was not lost... ..I am having a day, arn't I... ...I'm always learning.
  9. #19
    And my partial-point about transient filtering was not lost... ...I am having a day, arn't I...
    Joe,
    Your contributions are appreciated. The icon is not too subtle, is it?
    Joe
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
  10. #20
    Jun 2005
    Quote Originally Posted by VTC_WS6 View Post
    I haven't tried to do this with stock injectors. I don't know for sure how it would fair. If you do try it, proceed with caution and let us know what kind of results you get. To be safe, you could try reducing the stock IFR table some just incase...
    Remember, this method is in recognition of the idea that something is being fudged. Whether it's the MAF or the IFR table, something isn't right. As a result, we're trying to deal with it the best we can. My goal here is to get some 'outside the box' thinking going - especially since the opening line of this thread is....
    This is not the end-all-be-all bible to tuning. It's just 1 of 101 ways to tune that delivers consistant and repeatable results.
  1. Replies: 5
    Last Post: August 5th, 2008, 02:35 PM
  2. Tune VE and MAF tables or leave VE stock and tune MAF only
    Last Post: August 4th, 2008, 08:05 PM
  3. What else can I tune without scanning or black boxen it? Tune history inside.
    By Round Rock TJ in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2007, 02:27 AM
  4. Convince me to change to a 2bar tune...709rwhp through an EFI maf tune.
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 16th, 2006, 12:04 PM
