Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 100
Thread: Northstar info
  1. #31
    Feb 2008
    NEXT on to the 2000 to 2003 PCM. My Favorite
    That is 275 ft lbs. This ran a 14.7 this night, but not this run this run was a 14.8. This is a 2003 DHS 275hp 4400 lbs car and stock ran a 16.1
  2. #32
    Feb 2008
    NEXT on to the 1996 to the 1999 PCM
  3. #33
    Feb 2008
    NEXT on to the 2004 & 2005
    ALL OF THEM
    I have Stacks of Northstar PCM's all years. this is some of my 2000 to 2003's
  4. #34
    Feb 2008
    If you ever get board and want to waist a day or two you can read this cluster
    Northstar Tuning
  5. #35
    Feb 2008
    Northstar PCM History
    1996
    This used UART for communication with the ABS/TCS module only this year
    This ran 4 O2 sensors
    This had 2nd gear starts with TCS turned off
    It had no FTP sensor and used a purge switch
    This uses a Brake Booster Vacuum Sensor
    All of the cars used a VATS system in the IPC and Class II from the IPC to the PCM.
    The domestic calibration package = United States, Puerto Rico, U.S. Virgin Islands, Caribbean and Guam.
    The Unleaded Export calibration package K29 has some DTCs disabled and others have changed types (Type A to Type D, etc.). If a DTC has changed type or is disabled for the Unleaded Export calibration package. The Unleaded Export calibration package consists of vehicles sold in: Canada, Asia, Korea, Taiwan, Japan, Europe, Israel, Mexico, Iceland, South and Central America and Fleet/Govt./Military.
    I have other Cals that are not listed. This is from a TSB
    16256726 LD8 U.S. BASE CADILLAC DEVILLE/ ELDORADO/ SEVILLE SLS
    16256736 LD8 EUROPEAN EXPORT SEVILLE
    16256746 U. S. NOISE CONTROL SEVILLE / MEXICAN DEVILLE
    16256756 L37 U.S. CADILLAC ETC / STS WITH "Z" TIRES
    16256766 L37 U.S. CADILLAC ETC / STS CONCOURS WITH "H" TIRES
    16256776 EXPORT UNLEADED CADILLAC ETC / STS WITH "Z" TIRES
    16256786 EXPORT NOISE CONTROL CADILLAC ETC / STS
    16256796 EXPORT NOISE CONTROL CADILLAC CONCOURS
    16256826 CANADIAN BASE CADILLAC DEVILLE/ ELDORADO/ SEVILLE
    16256836 CANADIAN CADILLAC ETC/ STS/ CONCOURS WITH "H" TIRES
    16256846 CANADIAN CADILLAC ETC/ STS WITH "Z" TIRES
    NOTE: NOISE CONTROL HAS A DELAYED DOWN SHIFT
    1997
    This ran a second Class II circuit used by the ABS/TCS
    This had a few new DTC’s
    2nd gear starts when the TCS is turned off
    OLD CAL. NEW CAL. ENGINE
    NUMBER NUMBER RPO DESCRIPTION
    16244126 16256586 LD8 U.S. BASE CADILLAC DEVILLE/ELDORADO/SEVILLE SLS
    16244136 16256596 LD8 EUROPEAN EXPORT SEVILLE
    16244146 16256606 LD8 U.S. NOISE CONTROL SEVILLE/MEXICAN DEVILLE
    16244216 16256696 LD8 CANADIAN BASE CADILLAC DEVILLE/ELDORADO/ SEVILLE SLS
    16244756 16256616 L37 U.S. CADILLAC ETC/STS WITH "Z" TIRES
    16244766 16256626 L37 U.S. CADILLAC ETC/STS CONCOURS WITH "H" TIRES
    16245336 16256636 L37 EXPORT UNLEADED CADILLAC ETC/STS WITH "Z" TIRES
    16245346 16256646 L37 EXPORT NOISE CONTROL CADILLAC ETC//STS
    16245406 16256706 L37 CANADIAN CADILLAC ETC/STS/CONCOURS WITH"H" TIRES
    16245416 16256716 L37 CANADIAN CADILLAC ETC/STS WITH "Z" TIRES
    16256896 LD8 U.S. CADILLAC LIMOUSINE/FUNERAL COACH
    16245356 NF2 NM8 DUBAI , AE LEADED FUEL
    1998 & 1999
    The Deville’s and Eldo’s still use VATS system.
    The Seville used a PKIII system and an enhanced Class II system
    1998 did away with the Brake Booster Vacuum Sensor and the Purge Switch.
    They added a Fuel Tank Pressure Sensor
    1998 switched to 3 O2 sensors.
    I have found that some export programs will not start in Seville’s. I have not tried them in Deville’s with VATS
    1998
    09369826 LD8 U.S. AND CANADIAN CADILLAC ELDORADO BASE
    09369836 LD8 U.S. AND CANADIAN CADILLAC DE VILLE BASE
    09369886 LD8 U.S. AND CANADIAN CADILLAC SEVILLE BASE
    09369856 L37 U.S. AND CANADIAN CADILLAC ELDORADO, DE VILLE CONCOURS WITH "H" TIRES
    09369906 L37 U.S. AND CANADIAN CADILLAC SEVILLE WITH WITH "H" TIRES
    09369846 L37 U.S. AND CANADIAN CADILLAC ETC WITH "Z" TIRES
    09369896 L37 U.S. AND CANADIAN CADILLAC SEVILLE STS WITH "Z" TIRES
    09369916 LD8 U.S. AND CANADIAN CADILLAC LIMOUSINE/ FUNERAL COACH
    1999
    09366086 LD8 U.S. AND CANADIAN CADILLAC ELDORADO BASE
    09366096 LD8 U.S. AND CANADIAN CADILLAC DE VILLE BASE
    09366146 LD8 U.S. AND CANADIAN CADILLAC SEVILLE BASE
    09366116 L37 U.S. AND CANADIAN CADILLAC ELDORADO, DE VILLE, CONCOURS WITH "H" TIRES
    09366166 9388195 L37 U.S. AND CANADIAN CADILLAC SEVILLE WITH "H" TIRES
    09366106 L37 U.S. AND CANADIAN CADILLAC ETC WITH "Z" TIRES
    09366156 L37 U.S. AND CANADIAN CADILLAC SEVILLE STS WITH "Z" TIRES 9388186
    09366176 LD8 U.S. AND CANADIAN CADILLAC LIMOUSINE/ FUNERAL COACH
    Northstar Knock modules.
    Year-------------------First #------------Second # below-----PCM Hardware code
    1996 PCM ------- Module #16196410--------1585300-----------BTBU
    1997 PCM ------- Module #16196410--------1587112-----------CBRK--This ran to 125 mph but bucked after 110
    199? PCM ------- Module #16196410--------1587195-----------CBRK--I have ran this past 135 mph
    1999 PCM ------- Module #16196410--------1588106 --------- --I could not go over 100mph
    1998 PCM ------- Module #16196410--------1588058 -----------CHZP--I ran this to 125 mph.
    1998 PCM ------- Module #16196410--------1587149 -----------CHZJ--This ran to 130 mph
    1996 to 1999 PCM’s
    All of the cars ran the Same PCM service number 16214848
    It runs a Knock module
    It does not require a separate VTD relearn
    It does not require Crank Shaft Variance Learning
  6. #36
    Thanks CalEditor. The one you show as 2004 & 2005, does that do trans as well? I have a couple of those, one black, one not, but the same service number.
    I also have a Siemens TCM that was supposedly from the same vehicle, but I was under the impression the 2004-2005 engine computer does trans as well. Why else would it need 2 x CPU's!
  7. #37
    Quote Originally Posted by CalEditor View Post
    Northstar Tuning
    You're not wrong, there is a bunch of posts.
    Say, your avatar over there looks like TunerCats maps
  8. #38
    Lifetime Member MICK's Avatar
    Mar 2005
    Default Hummm
    Ross,
    TC (John), has packaged his software and customized it for a number of vendors.
    Jet Performance Products have purchased gas and diesel rights to the software. In doing so, the original unlimited version of TC was taken from the market. A limited number of original TC customers are still supported via John directly.
    Westers Garage (Lyndon Wester) has a version of the TC software customized for his customer bases. Westers has also supported a scan tool (PCM Scan) to work with the TC OBD2 interface. I would imagine this is what you see.....Correct Tom?
    Flash Chips (Ed Wright) may have a version of the TC software as well. Don't know much about this or if this information is correct. I have seen a version of the flash utility in the flashchips colours...
    The Only other Tuning Software I know of is the Real Time Roadrunner software supported via Craig Moates, God bless his mortal emulation soul.....LOL..Yep once you tune realtime it hurts to go back.
    MxScan (James Brimson) supports the Monodax forum and the MxScan scan tool software. I earn for the day that further developments in this software are made public as the GUI layout looks interesting.
    Until then, I will enjoy the use of EFILive.....
    Rev it up, Drop the clutch, See what happens?
  9. #39
    Quote Originally Posted by MICK View Post
    Interesting.....ah, yeah I guess so
    http://www.monodax.com/mxscan.htm
  10. #40
    Mar 2005
    Default Hummm
    LOL.
    You are a funny Man Ross!
    I tried to send you a PM but you obviously get hundreds of them as the return I got was that your mail box was full....TT.
    I was wondering if you could send me a copy of the 0411 Shelby Tune you have?
    Looking at new things is a passion I have.
    [email protected]
    cheers
    Mick
  1. Support for 2005 Bonneville GXP Northstar??
    By KAZ MotorSports in forum General (Petrol, Gas, Ethanol)
    Last Post: April 2nd, 2011, 10:00 AM
  2. Northstar support?
    Last Post: November 16th, 2007, 12:05 PM
  3. Northstar cadillac
    By 94caprice00gmc in forum General (Petrol, Gas, Ethanol)
    Last Post: August 30th, 2007, 03:33 AM
  4. Don't want a war, but need some info
    By serpa4 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 18th, 2007, 01:17 PM
  5. Any info on dates yet?
    By JxxxOxxxE in forum General (Petrol, Gas, Ethanol)
    Last Post: July 2nd, 2004, 03:00 AM
