It looks like this setting for the LC-1 is in the calc_pids file and the sae_generic file. Do both file have to be the same? Which one does it use first? I can change the calc_pids file but will I need to do the AutoTune over?
sae_generic file:
# Inovative LC-1 WBO2
*CLC-00-926
V 0.0 5.0 .1 "{EXT.AD1}"
AFR 10.0 20.0 .2 "({EXT.AD1}*3)+7.35"
*CLC-00-927
factor 0.0 2.0 .1 "{CALC.AFR_LC11.AFR}/{GM.AFR}"
*CLC-00-928
V 0.0 5.0 .1 "{EXT.AD2}"
AFR 10.0 20.0 .2 "({EXT.AD2}*3)+7.35"
*CLC-00-929
factor 0.0 2.0 .1 "{CALC.AFR_LC12.AFR}/{GM.AFR}"
# Calculate VE % by multiplying the VE value by molar mass of air (28.96) and the
# number of cylinders in the engine, then divide by engine displacement.
# - V8 is 28.96*8=321.68
calc_pids file- this is my file
# File details
# This section defines various details about the file format.
*FILE
#Parameter Value Description
VERSION 7.1.1 File version
DECSEP . Decimal separator used in this file
# Units
*UNITS
#Code System Abbr Description
# Add slot definitions here
*CLC-00-001
V 0.0 5.00 .1 "{EXT.AD1}"
AFR 10.0 18.0 .2 "(({EXT.AD1}-0.5)*3.3418)+7.35"
*CLC-00-002
factor 0.0 2.0 .1 "{CALC.AFR_LC11}/{GM.AFR}"
*CLC-00-003
V 0.0 5.00 .1 "{EXT.AD2}"
AFR 10.0 18.0 .2 "(({EXT.AD2}-0.5)*3.3418)+7.35"
*CLC-00-004
factor 0.0 2.0 .1 "{CALC.AFR_LC12}/{GM.AFR}"
CALC.AFR_LC11 F001 CLC-00-001 "V,AFR" Fuel "Wide Band AFR 1 - LC-1"
CALC.BEN_Lc11 F002 CLC-00-002 factor Fuel "Base Efficiency Numerator 1 - LC-1"
CALC.AFR_LC12 F003 CLC-00-003 "V,AFR" Fuel "Wide Band AFR 2 - LC-1"
CALC.BEN_LC12 F004 CLC-00-004 factor Fuel "Base Efficiency Numerator 2 - LC-1"
Thanks,
Bill
