Thanks for that....it makes sense.
I guess in those instances I may have been a little lean (which I haven't seen before...as being conservative with the VE table....it's always been rich and pulling fuel in RTACS).
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
