I made a script that does the following and thought I would share it for anyone that would be interested. It pretty much gets you set-up for a Open loop/SD tune. Here are the fields that it changes
Disable LTFT
Disable DFCO
Disable PE
Adjust Open EQ Table (14.63 Cruise/12.9 WOT)
Adjust DTC's (Disable Rear o2's, EGR, etc)
Disable EGR
Set MAF Rationality to 0 (Disables MAF)
Disabled COT
If someone see's anything I have missed, please let me know. I am trying to write a basic script for putting the car in Open Loop/SD and will be working on one for Closed Loop/SD.
File is below
