But how exactly are you logging the IFR? I read:
..I'm just not understanding what you are actually logging? When I open a new map in Scantool for example, I use the MANVAC pid as my row, use the BEN LC1 factor as the data but what am I using for the column, and how is the commanded AFR not influencing the final amount of fuel injected? Or should I be setting the same commanded AFR for an entire section of B3605 (say setting all rows 60-80*C ECT at 12.5 AFR) and then driving the car and hitting as many vacuum points as I can and then using the difference in commanded AFR and actual AFR to set the IFR amounts? (Did I just answer my own question?
