Results 1 to 4 of 4
Thread: "Service Airbag" message :(
    Dec 2007
    Default "Service Airbag" message :(
    Does EFILive support SIR testing, and/or clearing codes?
    Anyone care to PM me the mode and/or message to clear the BCM or SIR DTCs and I'll do it myself with my usbcan cable even?
    -Adam Chant
    Tune it or lose it!
    2007 Saturn SKY 2.4L Automatic - E67
    EFILive Tuned
    In the scantool there are options for reading/clearing DTC's from all modules...
    See under Edit->Properties->Advanced.
    Dec 2007
    Clear trouble codes from modules listed on [Modules] tab page.
    Is not implemented in E67 Controller.
    Also the modules listed are only the ECU and TCU.
    I tried both the V2 DTC clear and FlashScan DTC clear neither fixed the problem.
    I'm using V7.5 and latest beta BBL too.
    -Adam Chant
    Tune it or lose it!
    EFILive Tuned
    Dec 2007
    Oh SNAP Solved! I actually followed the disable procedure for the SIR system and it cleared the DTC.
    It's basically remove the Airbag fuse(s) and turn on the ignition to verify it's disabled. Disconnect the negative battery and wait 1 minute before working the SIR system. Then replace the fuse(s) and reconnect the negative battery cable.
    -Adam Chant
    Tune it or lose it!
    EFILive Tuned
  1. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  2. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
  3. Replies: 3
    Last Post: July 20th, 2006, 10:19 AM
  4. "service Engine Soon"?
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 29th, 2006, 12:50 PM
  5. "Service Brake System" message after tune change
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2005, 02:26 AM
