Page 10 of 21 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 202
Thread: options request : post your ideas
  1. #91
    Quote Originally Posted by mr.prick
    how about being able to open LS1edit and HPtuner files?
    or would that be way too much to ask.
    Yes, that's a little bit on the "far-away" side of way too much.
  2. #92
    They have their own proprietary encryption.
    There's also a mutual understanding between all parties... "you don't crack ours, we won't crack yours".
    Yeah, what Joe said.
    Or re-phrased, you don't publicly release our format that you've already hacked, and we won't publicly release your format that we've already hacked.
  3. #93
    Oct 2006
    Quote Originally Posted by 5.7ute
    Has any more progress been made on the accel enrichment tables. Even if it was limited to the COS it would help the FI guys out.
    Any news on this yet Blacky?
  4. #94
    Jan 2007
    Yeah...that help out immensely Mick.
    Transient fuelling!
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
  5. #95
    Nov 2006
    time to bump this thread.
    for RTACS,
    i would like to be able to set the update frequency per table
    instead of having a general setting.
    also i am wondering if it would be possible to make a COS
    for GEN3 (fbody/ybody) that could work with 58X reluctor.
  6. #96
    Lifetime Member Aloicious's Avatar
    Nov 2007
    Quote Originally Posted by hquick View Post
    Transient fuelling!
    x2 on the transient fueling.
    1996 c1500 gen1e 5.7L - the "LS31", 24x CNP, LS2 coils, modified T56, 12200411PCM running COS3, zz4 cam, custom MPFI, etc. coming soon: Twin Turbos
  7. #97
    Nov 2006
    is it possible to speed up the loading of logged data?
    large log files take an eternity to filter/load.
  8. #98
    Yes, currently (in V7) it is all done with disk buffers (long story - don't ask). V8 uses in memory buffers which is orders of magnitude faster.
    For a comparison, the V7 re-plot of 50,000 frames can take 5-10 seconds. On the same machine, a re-plot in V8 of 50,000 frames is less than 1/10th of a second.
  9. #99
    Default How about a custom operating system for engine swaps
    Since the advent of CAN or LAN it's getting harder to swap an E38, E67, or even an E40 into an old "junk" without using aftermarket guages and bypass the A/C circuit.
    I notice on GM's performance controller they have an oil and alternator light, not sure about cruise and A/C turn on signal.
    One thing I suppose we can do is find the O.S. of their performance controller and have it flashed in.
    Thanks for listening, you guys rock!
    John
  10. #100
    Default T42, T43 more tables
    How about defining/adjusting "hot mode" tables for T42,43?
    Also T43 missing tables for keeping Tap up/ Tap down "in gear"...NO overide.
    Thanks guys, I know this takes time!
    Cheers, John
  1. T43 Ideas
    By oztracktuning in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 9th, 2009, 02:12 PM
  2. E67 2.4 LE5 With VVT any Ideas?
    By Quasimotor in forum E37, E38 & E67 PFI ECM's
    Last Post: January 31st, 2008, 11:03 AM
  3. Any ideas up front
    By trudynosports in forum General (Petrol, Gas, Ethanol)
    Last Post: June 11th, 2005, 02:20 AM
