Code:
; _______________________________________________________________________
; | Copyright © 1999-2007 |
; | EFILive Limited |
; | web: http://www.efilive.com |
; | email: info@efilive.com |
; |_______________________________________________________________________|
; Modifications
; _________________________________________________________________________
; Version | When | Who | Why
; 8.0 | 2007-Feb-16 | PSB | Created file
; 8.0.1 | 2008-May-05 | KMS | Modified file to suit RX-7 tuning needs.
*PID_SELECTIONS
;PID selection list
; Cap1 and Cap2 form the "on-screen" display option from which the user may select.
; Controllers lists 1 or 2 "&" seperated pid memory map (*.pmm) files.
; PSL is the PID Selection defined later in this file
; PCU is the PID Custom Units defined later in this file
;Cap1 Cap2 Controllers (Engine&Trans) PSL PCU
General, Tuning, LS1B_M.pmm, General, PCU
Airflow, Bucking, LS1B_M.pmm, Airflow, PCU
CLSD, Trims, LS1B_M.ppm, CLSD, PCU
; PID Selection List
; Node: Is one of PCM, ECM or TCM (use "-" for external PIDs).
; PIDs: Is one or more "|" seperated PID names. The first valid PID will be used.
; Alarm: Is 5 ":" seperated fields:
; min: Minimum value, below which the alarm will sound.
; max: Maximum value, above which the alarm will sound.
; style: Is one of:
; 0 = No sound, No LEDs
; 1 = Low pitch
; 2 = Medium Pitch
; 3 = High Pitch
; 4 = Very high Pitch
; 16 = Illuminate LED 1
; 32 = Illuminate LED 2
; 48 = Illuminate LED 3
; 64 = Illuminate LED 4
; 128 = Illuminate LED 5
; Add Pitch and LED values together to enable audio and visual alarms.
; For example, for Medium Pitch and LED 4, use 2+64 = 66
; time: Time (in 10ms increments) for which alarm will be sounded.
; hold: Time (in seconds) for which the displayed value will be frozen (not implemented yet).
*General
;Node PIDs (pid1|pid2|...|pidn) Alarm (min:max:style:time*10ms:hold*sec)
PCM, RPM, 0:6600:3:1:0
PCM, TP
-, WO2AFR1
PCM, KR, 0:4:31:5:0
PCM, SPARKADV
PCM, ECT, -40:110:1:1:0
PCM, EOPS
PCM, IAT
PCM, MAP
PCM, VSS
PCM, DYNCYLAIR_M
PCM, IAC
PCM, IBPW1
PCM, AFR
PCM, W02ST1
*Airflow
PCM, TP
-, WO2AFR1
PCM, KR, 0:4:31:5:0
PCM, SPARKADV
PCM, IAT
PCM, MAP
PCM, VSS
PCM, DYNCYLAIR_M
PCM, IAC
PCM, IAC_TC_M
PCM, IAC_TF_M
PCM, IACDES_B
PCM, IACDES
PCM, IAC_STD_M
PCM, IAC_LTD_M
PCM, AFR
*CLSD
PCM, TP
-, WO2AFR1
PCM, KR, 0:4:31:5:0
PCM, SPARKADV
PCM, IAT
PCM, MAP
PCM, VSS
PCM, DYNCYLAIR_M
PCM, IAC
PCM, IAC_TC_M
PCM, IAC_TF_M
PCM, IACDES_B
PCM, IACDES
PCM, IAC_STD_M
PCM, IAC_LTD_M
PCM, AFR
; PID Custom Units
; PCU specifies the controller and PID for which to define a custom unit
; Caption is the caption displayed on screen during BB logging (8 characters maximum).
; Prec is the number of decimal places to display
; Units is the display units name.
; Op is the operator, one of:
; * = multiply
; / = divide
; i = invert_then_multiply
; The metric value of the PID is multiplied, divided or inverted then multiplied by Factor.
; Offset is then added.
*PCU
; PID Caption Prec Units Op Factor Offset
PCM,RPM, RPM, 0, rpm, *, 1.0, 0.0
PCM,TP, TPS, 1, %, *, 1.0, 0.0
PCM,AFR, AFR_CMD, 2, AFR, *, 1.0, 0.0
-,WO2AFR1, AFR_ACT, 2, AFR, *, 1.0, 0.0
PCM,KR, KR, 1, deg, *, 1.0, 0.0
PCM,SPARKADV, TIMING, 1, deg, *, 1.0, 0.0
PCM,ECT, ECT, 0, °F, *, 1.8, 32.0
PCM,IAT, IAT, 0, °F, *, 1.8, 32.0
PCM,MAP, MAP, 0, kPa, *, 1.0, 0.0
PCM,VSS, VSS, 0, mph, /, 1.609344, 0.0
PCM,EOPS, EOP, 0, psi, *, 32, -16.0
PCM,DYNCYLAIR_M, DYNCYLAI, 2, g/cyl, *, 1.0, 0.0
PCM,IAC, IAC, 0, steps, *, 1.0, 0.0
PCM,IAC_TC_M, T Crack, 2, g/s, *, 1.0, 0.0
PCM,IAC_TF_M, T Follow, 2, g/s, *, 1.0, 0.0
PCM,IACDES_B, IAC Flow, 2, g/s, *, 1.0, 0.0
PCM,IAC_STD_M, IAC STD, 2, g/s, *, 1.0, 0.0
PCM,IAC_LTD_M, IAC LTD, 2, g/s, *, 1.0, 0.0
PCM,IACDES, IAC Des, 0, Steps, *, 1.0, 0.0
PCM,SHRTFT1, STFT 1, 2, %, *, 1.0, 0.0
PCM,SHRTFT2, STFT 2, 2, %, *, 1.0, 0.0
PCM,LONGFT1, LTFT 1, 2, %, *, 1.0, 0.0
PCM,LONGFT2, LTFT 2, 2, %, *, 1.0, 0.0
