That is probably because EFILive can't communicate with the USB chip in FlashScan, try using MPRog to reprogram it. Then see if USBView can see a device called "EFILive FlashScan V2". If so, try the EFILive software again.
P.S. After reprogramming with MProg, it is recommended to unplug and replug FlashScan to allow Windows to reset the USB drivers.
Blacky looks to be working now.If it happens again whats my alternative, send it in?
Yes, if it happens again send it in and we will replace the EEPROM chip.
Send me your serial number to [email protected] and I will add a comment to our data base about it.
