Results 21 to 30 of 37
Thread: 1998 LS1 to 2000+ LS1 conversion?
  1. #21
    Try logging data for various sensors... and check for DTC's.
  2. #22
    Oct 2007
    ok. I downloaded an 02lsx pinout, and compared to my 02vortec pinout.
    Main differences seem to be which injector is plugged where. Also, the Lsx has coilpacks which vortec doesnt. There are a few other minor things like egr, airpumps, etc that one has, other doesnt, etc. But all main sensors plug into the same spots.
    11 Silverado
    08 Sierra
    91 RS with 350 TPI and 411 ECM
  3. #23
    Where is the back-flip emoticon??
    I have comms! I have fire! I feel like I have it all right now!!
    THANK YOU TO ALL THAT HELPED!!!
    This one took much longer than it should due to my tired brain yesterday and having to back-track today, but you guys helped me emmensely!!
    Beers are on me if any of you are in the CO Springs area!
    My gracious and sincere thanks,
    -Kenny
  4. #24
    Cool...
    What ended up being the problem (I want to mentally file away for future reference)...?
  5. #25
    Oct 2007
    Congrats!!
    Another for future reference.
    LS1 to L31 differences.......
    11 Silverado
    08 Sierra
  6. #26
    In Al's .doc at the bottom it states that Red C1-60 BRN, Blue C2-19 PNK (PCM IGN Feed), C2-58 PPL (Serial Data), and C2-20 ORN (PCM BAT Feed) remain in the same locations. I labeled them as stated above and plugged everything in...not paying attention to the COLOR code swap, just putting them to those pin locations.
    I put these in there proper place and wah lah. Tired brain fart I guess. Now it is time to play!
  7. #27
    Oct 2007
    ok, so to add to more confusion.
    I have found out that there is a 7.4l(L29) motor that uses the 0411 with the same OS as the LS1 and L31.
    But yet the pinouts are different. Even inside of that, depending upon what the L29 was issued in, the crank trigger, and pinout is different. So it goes deeper then ECM and OS.
    11 Silverado
    08 Sierra
  8. #28
    Hmmm... so the calibration binds the pinout.
  9. #29
    Dale do you have a copy of the tune file or VIN from this other 7.4 (L29)engine?
    Al
  10. #30
    Lifetime Member MICK's Avatar
    Mar 2005
    Default Hummm
    Hay Joe,
    There is a parameter table called installed options matrix which is tied into the platform code that has much to do with the pin out options. The platform code is number from 1 to 10 and on the other axis there is a swag of options to either enable or disable.
    You find things like the lean cruise option and a few other things in there.
    This is one area that will change the pin out in a PCM.
    Chees
    Mick
    Rev it up, Drop the clutch, See what happens?
  1. Need 1998 S-10 4.3 PCM Pinout
    By GAMEOVER in forum Vortec V6/V8 Specific
    Last Post: January 2nd, 2010, 11:02 AM
  2. 2000 LS1 conversion - getting incorrect ETC error.
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: May 20th, 2008, 03:26 PM
  3. I have a 1998 Camaro..
    By thosewhohatedmecreatedme in forum Custom Operating Systems
    Last Post: September 22nd, 2006, 06:56 AM
  4. 1998 WS6, Need some help......
    By Dick in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 2nd, 2006, 12:12 AM
  5. 1998 with 2 bar MAP
    By WicketMike in forum General (Petrol, Gas, Ethanol)
    Last Post: February 13th, 2006, 05:00 PM
