Have the TPS position issues with E38/E67 processors been resolved? I find that in both bbl and when using V2 in pass-through that max indicated TPS is 80-88%
DigitalEFI- EFILive US Distributor
[email protected]
678/344-1590
I found this post and multiple links confusing. Tell me if this looks correct:
Download and overwrite current data in following order:
http://download2.efilive.com/Softwar...ch_26_2008.zip
http://download2.efilive.com/Softwar...il_14_2008.zip
http://download2.efilive.com/Softwar...il_26_2008.zip
http://download2.efilive.com/Softwar...ay_06_2008.zip
Press CTRL on V2 device, then plug in USB Cable.
Write Firmware Using V8/EFILive_Explorer.exe->>Downloaded from May 06 2008 Update
v2.4.72
Using Same, update to
2.5.8 BootBlock
2.5.17 (506)
Refresh Indicates 2.5.8 Bootblock and 2.5.17 (506) firmware. I hope this works.
07 Silverado DMax Classic
Yes, that's right, but just to clarify the FlashScan update process:
1. Update firmware to V7.4.72 using FlashScan Firmware programmer.
2. Use the menu option in FlashScan to upgrade boot block to V2.05.08
3. FlashSCan will stay in dead poll (two flashing orange LEDs) until new V2.05.xx firmware is programmed.
4. Use EFILive_Explorer.exe (downloaded as part of the BBL download) to reprogram the V2.05.17(0506) firmware.
That should be all you need to do.
After installing Bootblock V2.05.08 and the latest firmware I logged a test session (E38 ECM). I moved the logfile in explorer to (logged Data) in V 7.5.3 and I get a pop-up(in the scan tool) that says the file needs to be opened with 7.5 or later ( thats what I am using) any idea what this is?
I have included the log file I cannot open.
Thanks, Jim
08 Z06
The error message is wrong, it should say you need to use V7.5.4 or later, not just 7.5 or later.
To update your EFILive software to V7.5.4, you need to extract ALL the files in the BBL download zip file into the folder: \Program Files\EFILive\V7.5 (overwrite existing files).
When logging Commanded AFR for my E38, I use the following line in the options.ini file....
ECM, AFRATIO_M
This works for me.
Simon
