Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 49
Thread: Bootloader Error
  1. #31
    Mar 2007
    Success!
    Read and Flash!
    Thanks Paul. You have mail.
  2. #32
    Lifetime Member bobo's Avatar
    Nov 2005
    Quote Originally Posted by JOHNBOY View Post
    Success!
    Read and Flash!
    I wish
    Should have left it stock
  3. #33
    Mar 2007
    Quote Originally Posted by bobo View Post
    I wish
    Sorry to hear about the bad luck Bob.
  4. #34
    Mar 2007
    Quote Originally Posted by McRat View Post
    That works out PERFECT!
    I have no patience, and I don't lock tunes.
    I get the same bug, but I can usually force it via the turning the highspeed off, and reconnecting everything.
  5. #35
    Feb 2009
    Hi i read this thread and i am new to the forum. I have been in the diesel place forum for over a year now. I am having the exact same problem with my 2002 LB7. I am stumped. Please help!
  6. #36
    Please check through the lists in post #7 and #8.
    Also please send file as per post #24.
  7. #37
    Quote Originally Posted by Bmilla97 View Post
    Is this the same vehicle we have been dealing with on Diesel Place?
  8. #38
    Feb 2009
    Yes i thought maybe someone might see it here that isnt part of diesel place. Well i checked the EFI LIVE forum last night and someone else had the same problem as me. On of the replies said to enter F$$$$ in the keys spot above alt keys. That would let me upload the current settings but not let me flash. I tried the alt keys and no high speed but it did nothing. ive reflashed the truck maybe 20 times over the last year and im really good at remembering numbers. I was sure i saw the seed # was $2333. I tried it and, IT WORKED!!! I cant believe i remembered the seed number! I havent reflashed in 3 months! There have been a few people with the same problem. Some of them bought new ECM s. I wish they would have written down the seed number. It seems like the ECM forgot or lost the seed number. But when put in manually it works. I would urge any LB7 owners to record the seed number from their truck... one day it might save your a**! Thanks for all your help from everyone on here. This was the first time i posted a problem. This was very helpful. Now i have to go try and help a couple people that are stuck like i was.
    PS. I did upgrade to the latest version of EFI LIVE last night, dont know if that helped any.
  9. #39
    The 2001/2002 Duramax ECM has a habit of losing data, not all the time, but it happens, it's even worse when you let TechII near it, I am impressed you remembered the key!
  10. #40
    Mar 2012
    I have had this issue the last week. Paul from efilive sorted me out quick smart.
    Because the pcm had failed to flash completely it did a recovery flash and locked the PCM automatically.
    All i had to do was put the seed number in as the key and it unlocked the computer.
    Cheers to EFILIVE support for their help.
  1. bootloader error will not reflash
    By toolie in forum Duramax LB7
    Last Post: June 20th, 2010, 10:10 AM
  2. Bootloader error when getting stock tune
    By TrevorB in forum Duramax LB7
    Last Post: October 8th, 2009, 02:17 PM
  3. Bootloader error and no calibration!
    By horsehaulin in forum Duramax LLY
    Last Post: August 16th, 2009, 04:25 PM
  4. Bootloader Rejected error during reading calibration data
    By Godwin1245 in forum Gen III V8 Specific
    Last Post: January 26th, 2009, 01:25 PM
  5. Bootloader-
    By GMjohn in forum E37, E38 & E67 PFI ECM's
    Last Post: November 28th, 2007, 08:30 PM
