Results 1 to 4 of 4
Thread: 07 escalade vvt w/ a 07 cts-v 6 spd tune
    Member nycblazer's Avatar
    Jan 2008
    Default 07 escalade vvt w/ a 07 cts-v 6 spd tune
    hello guys
    what i have here is a 2007 cadilac escalade 6.2L vvt engine mated to a t56 6 speed manual. i had the engine harness custom made, instead of using the e38 2 plug ecm i had the engine harness made for a e67 3 plug ecm. the reason why was because the 2007 cadilac cts-v came with a ls 6.0 engine mated to a t56 and it uses the e67 3 plug ecm.
    know i have the engine and tranny in the car all the guages work oil pressure is up to 40-45 the engine cranks fine but it wont start. checked for spark and i got no spark. now can it be the security bullcrap vats from gm.
    this engine is installed on my 1999 s10 blazer 4 dr. what else can i look for.
    if it is the gm security how do i get rid of that i have the efilive v2 scanner, with it i installed the 2007 cts-v program with the vats off.
    can you guys give me some advice. i've been working on my truck for the last 3 month and now im up to the end, getting ready to start and it wont start.
    It might be the VATS still.
    If you want to email me your file to [email protected] I'll patch it for you.
    Jan 2008
    email sent
    Jan 2008
    here it is can someone delete the vats. i thought it would be easy by just clicking no. i guess not, then it ask me for a patch now where do i patch .
    all i want to do is to get my blazer running. right now i dont have spark or fuel when i crank it. i do have oil pressure. also i did not have to press in my clutch in for the starter to crank, it cranks the engine without having to press the clutch wierd.
    would this tune work on a L92 engine with vvt, or should i load the original 2007 L92 6.2L VVT stock tune. the only problem is the engine harness was made for a e67 ecm and the original tune for this engine uses a e38 ecm
  1. Escalade gear ratio reading
    By 68skylark455 in forum General
    Last Post: January 28th, 2010, 10:34 AM
  2. Cadillac Escalade ESV Scan ??
    By stevieturbo in forum Gen III V8 Specific
    Last Post: March 4th, 2009, 01:33 PM
  3. 2007 Escalade + BBL
    By Tony @ MPH in forum FlashScan V2 BB Logging
    Last Post: January 14th, 2008, 05:35 PM
  4. Knock retard on LQ9 - '06 Escalade (HELP!)
    By Boost in forum Gen III V8 Specific
    Last Post: October 6th, 2007, 08:49 AM
  5. Looking for stock file for 2002 Escalade
    By JR_VETTE in forum Gen III V8 Specific
    Last Post: June 27th, 2007, 12:54 AM
