Results 1 to 7 of 7
Thread: problem with the speedometer
    Apr 2008
    Default problem with the speedometer
    guys,
    who knows how to solve the following issue: whenever I change the diff ratio, the shift point correction won't show any table to adjust!!!
    Please look at the attachments
    Regards,
    Odd Boy
    The list of shift tables to update is stored in the file:
    \Program Files\EFILive\V7.5\cal_adjust.txt
    You can add a section that matches the controller you are working on:
    [LS1A] = 97/98 LS1
    [LS1B] = 99+ LS1
    [T42] = T42
    [T43] = T43
    [ALLA] = 5 speed Allison
    [ALLB] = 6 speed Allison
    Then put a list of all the tables that you want updated by the shift point adjustment into that section. Then save the file and restart EFILive.
    The "=Yes" or "=No" setting signifies whether the table's check box is checked or not in the list.
    Paul, I just checked in my V7.5 folder and that file is under \Program Files\EFILive\V7.5\Configurationcal_adjust.txt, might be something to do with the new V8 beta stuff?
    Very cool to know about this file, definitely going to be using this feature now!
    You're right, my mistake.
    It is in \Program Files\EFILive\V7.5\Configuration\cal_adjust.txt
    Regads
    Hint: The section names you must use for various controllers, are the same names as the folder names in the Calibrations folder.
    Apr 2008
    thanks to you all
    Regards,
    Odd Boy
    Good to know, thanks!
  1. From a M6 to 4L80 speedometer problem
    By RandyWS6 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 6th, 2009, 12:12 PM
  2. Problem with speedometer
    By mrialsm4 in forum Gen IV V8 Specific
    Last Post: February 21st, 2008, 07:38 AM
  3. Speedometer Setting
    By lplott in forum General (Petrol, Gas, Ethanol)
    Last Post: November 30th, 2006, 03:56 PM
  4. Changing speedometer
    Last Post: August 9th, 2006, 04:20 AM
  5. Same OS different Speedometer Seg ID's
    By heavyfoot in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2006, 02:02 PM
