Results 31 to 37 of 37
Thread: 1998 LS1 to 2000+ LS1 conversion?
  1. #31
    G'day Mick,
    That table is only visible using the factory software tools...?
    It would be interesting to have access to it...
    Joe
    Quote Originally Posted by MICK View Post
    Hay Joe,
    There is a parameter table called installed options matrix which is tied into the platform code that has much to do with the pin out options. The platform code is number from 1 to 10 and on the other axis there is a swag of options to either enable or disable.
    You find things like the lean cruise option and a few other things in there.
    This is one area that will change the pin out in a PCM.
    Chees
    Mick
  2. #32
    Lifetime Member MICK's Avatar
    Mar 2005
    Default Hummm
    Joe,
    That table is available to who ever includes it into there definition template.
    I see it in TC software.
    Here is a snapshot of the table from a 02 vett Z06.
    There is also a parameter constant to select the platform code.
    Yes...makes things interesting if your chasing LC on a US operating system but that is another story....
    I'm sure you get the drift.
    Mick
    Rev it up, Drop the clutch, See what happens?
  3. #33
    Mick,
    Very interesting indeed (hmmm, I see...)...
    I wonder if there is an option for running MAF/MAFless...?
    (the reason I ask is that when failing the MAF, the resulting DTC's seem to inhibit some of the trans features like adaptive shift learning).
    Joe
  4. #34
    Guys,
    I truly wish I could post the dyno charts for this car, but I have been sworn to secrecy until after he runs it at the strip. What a change from the HP Tuners 2 bar conglomeration of crap for the 1998 PCM to this. As soon as I get the go ahead from the client I will post up the before and after graphs.
    My much appreciated thanks to all who led me down this path! You guys helped me be the hero on this one!
    Best,
    -Kenny
  5. #35
    Mar 2005
    Default Hummm
    Mick,
    Joe
    Joe,
    I see a speed density parameter option in the constants for the V6 only.
    The V6 platforms I have seen run up to 140kpa with a S/C option as well.
    There is quite a difference in the V8 platform.
    One can only assume that the Maf calculations are very important in the trans shift patterens with respect to calculated load and learning on a OEM platform.
    Mick
  6. #36
    Mick,
    Oh, we also found that failing the MAF seems to disable misfire detection.
    Joe
  7. #37
    Oct 2007
    Quote Originally Posted by ChipsByAl View Post
    Dale do you have a copy of the tune file or VIN from this other 7.4 (L29)engine?
    Al
    Sorry, havent been back on sense I posted this. I found a PCM out of a k2500 truck, got it in yesterday. Havent had time to scan it due to graduations.
    Plan to in next few days and try to submit it to holdencrazy.
    Ive been told the crank signal between the 7.4 in the k2500(4x) and crank signal 7.4/utility trucks(24x) is different.
    11 Silverado
    08 Sierra
    91 RS with 350 TPI and 411 ECM
  1. Need 1998 S-10 4.3 PCM Pinout
    By GAMEOVER in forum Vortec V6/V8 Specific
    Last Post: January 2nd, 2010, 11:02 AM
  2. 2000 LS1 conversion - getting incorrect ETC error.
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: May 20th, 2008, 03:26 PM
  3. I have a 1998 Camaro..
    By thosewhohatedmecreatedme in forum Custom Operating Systems
    Last Post: September 22nd, 2006, 06:56 AM
  4. 1998 WS6, Need some help......
    By Dick in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 2nd, 2006, 12:12 AM
  5. 1998 with 2 bar MAP
    By WicketMike in forum General (Petrol, Gas, Ethanol)
    Last Post: February 13th, 2006, 05:00 PM
