is the shit. That was a very good idea and will save a lot of time espcially on DTC and MILS. Kudos to the EFILive crew for thinking tat one up.
What other neat tricks were added in this release
You can thank wait4me for that one. It was his idea
What kinds of things have guys been using it for. I've never used it.
It's an automated way of modifying anything you do to a tune file. Here's an example that I wrote a few days ago. This script modifies all of the injector tables to the accommodate the Bosch 36 lb ASA/GTP injectors. It's much easier to do it this way than copy/paste manually.
Aaron
'03 Z06 Corvette - The normal stuff...
EFI-101, EFI Advanced, EFILive-101
EFI University Evangelist
Hey Aaron,
thanks for all the scripts.
Could I ask you to do one for the Bosch 42lb injectors?
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
