Page 1 of 11 123 ... LastLast
Results 1 to 10 of 106
Thread: BB Logging beta update: May 19, 2008
    Default BB Logging beta update: May 19, 2008
    IMPORTANT
    IF YOU HAVE NOT ALREADY DONE SO,
    YOU MUST UPDATE FLASHSCAN'S BOOT BLOCK TO V2.05.08(0426)
    BEFORE
    YOU ATTEMPT TO UPGRADE THE FIRMWARE TO V2.05.16 OR LATER.
    Under no circumstances should you attempt to use boot block V2.05.06 (released March 26, 2008).
    See this link for more info on what is wrong with V2.05.06
    http://forum.efilive.com/showthread.php?t=7804
    Download here: http://download2.efilive.com/Softwar...ay_19_2008.zip (20Mb)
    This download includes and supersedes all previous BBL beta downloads.
    ALL *.pmm files have been updated. you MUST delete ALL *.pmm files from FlashScan (before upgrading the firmware) and from the folder: \Program Files\EFILive\V8\config (before unzipping the downloaded zip file). Failure to do so will cause unpredictable results when you restart FlashScan after updating the firmware to 2.05.17(0519).
    The Readme_First.pdf file included in the zip file has not been updated, except to update version numbers.
    The FlashScan AutoCal V2.5 Release Notes _beta_.pdf file has some important "Known Issues" asnd updates. Please read them.
    The FlashScan AutoCal V2.5 Quick Reference _beta_.pdf file has not been updated.
    Make sure you update your FlashScan (and/or AutoCal) firmware and boot block using the latest *.efw files from the \Program Files\EFILive\V8\Firmware folder.
    Oct 2005
    Not sure if this has been posted before, but even though I flashed the latest bootloader 2.05.08(0426) the Explorer and V2 show a date of Apr. 25, 2008.
    2005 RCSB 2500HD GMC Sierra DURAMAX LLY
    1955 Chevy Truck 1st series, being restored
    2002 Mercedes C270 CDI
    You also need to update FlashScan with the latest firmware file: FSProgV2.05.17(0519).efw (from the Firmware folder).
    VPW mode $06 still says "Mode $06 Data Not Retrieved".
    Still not implemented. :(
    swingtan
    Guest
    Excellent work! I'm now trying to get my head around the "Dynamic" section in the E38 Fuel group. It's early days yet but the excitement is growing.
    It did prompt me to remember something that I worked out way back in January and may have forgotten to pass on.
    In the PE tables, B0156 provides a TPS% level to enable PE. I found that measured TPS% was vastly different to the PE% displayed in the table. I had all sorts of troubles trying to work it out so I started remapping the measured TPS% vs TuneTool TPS%. The results showed that there was a logarithmic offset between the 2 values, as shown in the attached image.
    While there are differing thoughts on weather PE should be controlled by TPS%, MAP or both, there is a question as to what other TPS% settings may be effected by this offset?
    Simon.
    Paul,
    That's ok, take your time... I was going by the quick reference guide...
    I'm having some cat codes so I am playing around with mode 6.
    Joe
    swingtan
    Guest
    I did a couple of logs this afternoon. Replaying them in ScanTool has dropped a couple of the PIDs off. They exist in the log file but do not display. I copied the previous options.ini file back into the config filesystem as I didn't see any info in the readme to say there were changes and it was fine before.
    The following PIDs no longer show up in the ScanTool...
    • ECM, INVLVTMP_M
    • ECM, OCTSCL_M
    • ECM, AFRATIO_M
    Sample log file is attached.
    Lifetime Member hymey's Avatar
    Jan 2008
    Has anyone tried pass thru logging yet?
    • ECM, INVLVTMP_M
    • ECM, OCTSCL_M
    • ECM, AFRATIO_M
    Is it possible you've exceeded the channel count?
    24 for VPW, 42 for CAN?
  1. BB Logging beta update: May 12, 2008
    Last Post: May 27th, 2008, 09:01 AM
  2. BB Logging beta update: May 06, 2008
    Last Post: May 22nd, 2008, 10:57 AM
  3. BB Logging beta update: May 03, 2008
    Last Post: May 5th, 2008, 02:43 PM
  4. BB Logging beta update: April 14, 2008
    Last Post: April 23rd, 2008, 08:46 PM
  5. BB Logging beta update: March 26, 2008
    Last Post: April 6th, 2008, 06:43 AM
