![Quote](images/misc/quote_icon.png)
Originally Posted by
TFZ_Z06
BBL and Pass Thru are working. Accuracy is set to 1% and I have not changed it. I DO NOT want it updating the RR right now, only the opened tune file.
Am I wrong or does:
Non_Emulate Mode - > Write to currently opened tune file only.
Emulate Mode-> Writes Only to Tune File AND RR.
The RR has two modes of operation:
1. Emulation mode: Update Roadrunner PCM as changes are made in real-time. The button indicated by (1) toggles it into [Emulation] mode. When this mode is active, [Emulation] is displayed next to the RR firmware version number and the words -Realtime- are displayed on both sides of the word 'RoadRunner'. This is what the RR control panel looks like when in emulation mode:
![](http://www.andersonperformance.net/rr1.jpg)
2. Flash mode: Execute PCM from Flash memory. When the [Flash] mode button is toggled, the RoadRunner goes into [Flash] mode. The word [Flash] appears next to the RoadRunner firmware version and all this text turns red. In this mode, the PCM operates from the embedded flash exactly as though it were a 'standard' PCM. You can read the flash or reprogram the flash using your standard EFILive FlashScan tools.
![](http://www.andersonperformance.net/rr2.jpg)
TFZ_Z06
No, I have not connected before. I've only had the RR in about 2 weeks or less. Also, I did turn on the red emulate button and nothing happened.
![Help2](images/smilies/oldforum/help2.gif)
For [Emulation] mode to work, you must 'connect'. Nothing will happen when your in emulation mode except that the RR control panel will display as shown above. At this point, if you make a change to a table the RR will execute the change in realtime.
TFZ_Z06
What are fields 1 and 2 for???????????????????????
(1) is the feedback PID calculated value and (2) is the feedback PID used for the RTACS process. (2) is defined in the cal_link.txt file, see below for more information.
![](http://www.andersonperformance.net/rr5.jpg)
The PID/Table relationship is defined in the cal_link.txt file located: C:\Program Files\EFILive\V7.5\Configuration
An example of a RoadRunner linked PID to {B0101} is:
Code:
;Main VE Table
B0101.ROW=SAE.RPM
B0101.COL=SAE.MAP
B0101.RRR=CALC.BEN1,CALC.BEN2,CALC.BEN_AUT1,CALC.BEN_AUT2,CALC.BEN_FJO1,CALC.BEN_FJO2,CALC.BEN_LC11,CALC.BENLC12,CALC.BEN_LM11,CALC.BEN_LM12,CALC.BEN_PLX1,CALC.BEN_PLX2,CALC.BEN_TE1,CALC.BEN_TE2,CALC.BEN_WBC1,CALC.BEN_WBC2
[{Reference_Number}.RRR= xxxx.xxxx] is the list of feedback PIDS that link to this table.
For RTACS to activate, you must meet the following conditions:
1. RoadRunner PCM must be connected to the tune tool software.
2. The real time update tool bar button must be selected.
3. The scan tool software must be logging data.
Then you must select either the RTACS fine or course adjustment buttons on the tool bar. In the image, (1) is the fine adjustment, (2) is the course adjustment, and (3) is the cell edit mask feature.
(From page 89 of the EFILive v7.5 tune manual)
![](http://www.andersonperformance.net/rr4.jpg)
You can adjust the step size of the fine and course adjustments in the Tune tool properties. From the tool bar - Edit >> Properties >> RoadRunner:
![](http://www.andersonperformance.net/rr3.jpg)
The 'Update Frequency' parameter in the above image controls the number of cell hits required for RTACS to consider a cell 'valid' for modification.
TFZ_Z06
Do you know where I can find the functions, such as dx(), lookup() and the syntax for using them?
Parameter Identifier (PID) information starts on page 89 of the EFILive Scan manual. Functions available are specifically on pages 93-94.
TFZ_Z06
I'll go out and play with it again. The #*$*#**#$% USB cable is so short it barely reached my laptop.
Use a USB extension cable or purchase the Bluetooth option.
TFZ_Z06
Again, RRR is for????????????????
Thanks for help so far....
I don't know what 'RRR' means. Probably just a specific variable for RoadRunner operations.
Did you configure EFILive according to the RoadRunner quickstart guide?
