I have 02020003 V3 and all the tables are numbers instead of stoich, real irritating! Is there a version or a way to convert what I'm using so its easier to program?
Also, in speed density mode can all the fuel calculations be off just ONE table instead of 50 tables all modifying each other!?
The way I see it, I need a base map, cold enrichment map and an accelerator(TPS) map. This is a drag racing only application and there just does not need to be so many modifying tables!!!
Lee
