Results 1 to 10 of 13
Thread: Transient Fueling and CFCO Settings
    swingtan
    Guest
    Default Transient Fueling and CFCO Settings
    Hi Guys,
    While playing around with the new "Transient Fueling" parameters I think we may need some additional settings for Clutch Fuel Cut Off to go with them. the auto boys probably won't care too much, but for for us manual guys, we get a fuel cutout each time the clutch is pressed. This of course creates lean spikes that can cause problems when jumping back on the loud pedal. I've had a play with B2005 to see what effect it has and found it does seem to reduce the spike a bit. But I wonder if it would be better if we could time the beginning of CFCO like we can for DFCO. Having a setting like B2401 for CFCO would allow us to prevent any CFCO for say 0.5 seconds, stopping the lean spikes when at the track but shutting down fuel on lazy shifts on the road.
    An additional finding is that I think all wall wetting settings are tied to the MAF. I tried some tests with turning off B2020 while I was running full SD and there was virtually no difference to the measured AFR's during throttle movement when compared to when B2020 was turned on. Re-enabling the MAF has shown a reduction in lean spikes when the throttle has large movements. Do we need a patch to enable wall wetting when in SD mode?
    Simon.
    Jan 2007
    WHAT TRANSIENT FUELLING TABLES????
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    swingtan
    Guest
    You need an E38 Howard....
    Lifetime Member hymey's Avatar
    Jan 2008
    I back swingtan's comments. I think a CFCO table would be very handy in the fuel section. I have been speaking to Simon on this one and is there any possibility of including it in the next update
    The stomp B2005 table works a bit but not enough to overcome lean spikes when running mafless. When racing at the track I consistantly lost et from lean induced knock retard on gear change.
    Going back to the MAF tune fixed the problem, no lean spikes and no need to fiddle with B2005.
    CFCO still works with the MAF installed, which directly points to dynamics fueling being the culprit.
    If we could disable CFCO it would allow us to run mafless with no lean spots on gear shifts which works as a patch in a kind of way until dynamics has been solved.
    Joel
    I never said the tables were a true AE table!
    CFCO shutoff parameter will be in the next update.
    Jan 2008
    Thanks for that Ross, that will help a lot.
    cheers
    swingtan
    Guest
    Excellent Ross. Good work again!
    Oct 2005
    Excellent Sir. It makes shifting horrible. I have to shift with throttle part way down to make shifts smooth in mafless.
    Pint coming your way at SEMA
    2014 VF SV LS3 Maloo.
    Are you coming to SEMA this year?
    Just a bowl of wings will suit me fine
    Oct 2005
    Yes, SEMA all sorted.
    I need to check out the 09 camaro in more detail
  1. Transient Fuelling Pid
    By 5.7ute in forum Tips and tricks
    Last Post: April 8th, 2012, 11:35 AM
  2. Will changing the VE map alter accel pump/transient fueling?
    By Supercharged111 in forum Vortec V6/V8 Specific
    Last Post: June 18th, 2009, 08:10 PM
  3. Can CFCO = No Lift Shitft?
    By 4wheels in forum Gen IV V8 Specific
    Last Post: May 3rd, 2009, 07:01 AM
  4. 2008 Z06 Spark issue, was it CFCO?
    By Tony @ MPH in forum E37, E38 & E67 PFI ECM's
    Last Post: March 3rd, 2008, 01:54 PM
