Results 1 to 4 of 4
Thread: Help, why can't I pull timing through my AIT?
    Feb 2007
    Question Help, why can't I pull timing through my AIT?
    I have the iat relay/resistor trick done to try to pull timing when spraying, and by looking at the logs, my iat jumps to 178deg as soon as the noids open, but I get no timing retard??? My timing stays right where the high octance table says?????
    Here is the log, and related screen shots from my tune.
    Does anyone have any ideas?
    BTW, this is an 05 GTO
    TIA,
    Vinny
    To try and trouble shoot that setup, log the two PIDs: GM.EST_IAT_DMA and GM.EST_ECT_DMA. They should show you the contribution to the final spark due to ECT and IAT.
    However, I recommend using our custom nitrous operating system which has built in spark and fuel correction tables that allow you to directly control spark and fuel at the flick of a switch wired directly to the PCM. That way you don't have to fool the PCM with bogus values from the IAT sensor.
    Feb 2007
    I'll try logging them, and let you know what I see.
    I'd love to use a custom operating system, but I have an LS2, so...
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Quote Originally Posted by 860 View Post
    Unless there is one you are hiding from us Paul.............
    Dave.
  1. Displacement not on pull down
    By dennisscars in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: May 24th, 2009, 01:15 PM
  2. I'll try this in here, anyone get too much timing pull with COS5?
    By Loudmouth LS1 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: March 31st, 2009, 08:25 AM
  3. Can't pull LS7 SMS and O2 data
    By leres in forum E37, E38 & E67 PFI ECM's
    Last Post: July 27th, 2007, 10:41 PM
  4. Pull timing with bidirectional controls to test for KR?
    By Xtnct00WS6 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 27th, 2006, 04:11 PM
  5. What else could pull timing?
    By QUICKSILVER2002 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 1st, 2006, 11:24 PM
