No instructions so I'm assuming (we all know what that word means ) it's pretty straightforward????
Anyone installed one before?
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
RoadRunner LS1 Realtime Emulation PCM - $599.00
Roadrunner-DIY: "Guts" Kit $489.00
For $110 is it really worth the effort? For the extra $110 you get a complete and tested RR with backup and warranty.
It's all good until it goes "Bang"
It's all done and I can connect to the RR.
The issue I have now is the message telling me it's not licenced to EFILive???
Howard
DUCT TAPE.
To use your RR with EFIlive you also need to buy a RR EFILive realtime license at $199. You also need to enter the RR's serial number into you scan tool in the registration box as shown in the attached pics.
Yep...bought the licence and have all the info installed
Says set to demo.
Howard
DUCT TAPE.
Have you installed it into a new license tab by itself, or did you modify your existing license tab and add the RR serial number and new license key?
installed it into the #1 position
Howard
DUCT TAPE.
Don't know what I did....but it's now working.
Howard
DUCT TAPE.
