Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 82
Thread: BBL installer update: June 12, 2008
  1. #41
    Oct 2005
    At this stage it will only switch your DSP tunes.
    Does this mean the latest OSs do support DSP5 V2 switchable tunes now?
    2005 RCSB 2500HD GMC Sierra DURAMAX LLY
    1955 Chevy Truck 1st series, being restored
    2002 Mercedes C270 CDI
  2. #42
    Lennart, let me know what OS you are running if you want to test it, they are all done ready to go.
  3. #43
    Jul 2007
    How are the "Favorite Parameters" stored? I still have the old folder. Can I get my favorties back?
    07 Silverado DMax Classic
  4. #44
    Sep 2003
    Quote Originally Posted by TFZ_Z06 View Post
    Go to your 'old folder' and copy the "cal_favorites.txt" file from the "C:\Documents and Settings\Owner\My Documents\EFILive\V7.5_Old\User Configuration folder into the new "\User Configuration" folder.
  5. #45
    Oct 2005
    Ross,
    I am running a DSP2 OS right now: 05875801
    The matching DSP5 would be: 05875805
    Thanks,
    Lennart
  6. #46
    Dec 2007
    efilive explorer wont let me close it down keeps popping up a screen saying (cannot create file "c:program files\efilive\v8.1\programs\efilive_explorer.ini" . access is denied) any one have any clues?
  7. #47
    Jan 2004
    I'm gonna test this new firmware out tomorrow probably on a long trip to see if the E38 BBL issue pops up or not.
  8. #48
    Quote Originally Posted by newguy2diesel View Post
    Are you using vista?
    http://forum.efilive.com/showpost.ph...3&postcount=88
  9. #49
    Quote Originally Posted by XLR8NSS View Post
    Should be good to go. I logged over 160,000 frames (just over an hour) on an E38/T43 combo with no problems.
  10. #50
    swingtan
    Guest
    A quick update on connecting the V2 to a Holden VZ E38 ECM.
    1. Any alerts / warnings: None so far
    2. Protocol Detection with ignition on: Yes, detects CAN OK.
    3. Connecting with Ignition off, then turning on ignition: All fine, reads VIN & OS with no need to replug.
    4. DTC's and FF: None to read ATM.
    5. SD Card: Working fine.
  1. BBL installer update: June 22, 2008
    Last Post: July 3rd, 2009, 05:28 PM
  2. BBL installer update: June 12, 2008
    By Chevy366 in forum FlashScan V2 BB Logging
    Last Post: June 13th, 2008, 10:37 AM
  3. June V2 update
    By jfpilla in forum E37, E38 & E67 PFI ECM's
    Last Post: August 13th, 2007, 11:09 AM
  4. Minor typo in the June 13th update
    By leres in forum E37, E38 & E67 PFI ECM's
    Last Post: June 14th, 2007, 05:27 PM
