Results 1 to 7 of 7
Thread: RED border????
    Jan 2007
    Default RED border????
    HI All,
    does anyone know what it means when you're using the RR and the border around the table you're auto correcting turns red instead of the usual blue?
    I've seen this a couple of times whilst auto VE'ing the main VE table.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Nov 2006
    i think the colors represent which way the BEN is being applied.
    multiplying up or down.(lean/rich)
    Jan 2007
    Thanks for that....it makes sense.
    I guess in those instances I may have been a little lean (which I haven't seen before...as being conservative with the VE table....it's always been rich and pulling fuel in RTACS).
    Howard
    DUCT TAPE.
    Oct 2006
    I always thought it meant the cell wasnt in the target value but the filters were active preventing correction. Never really took that much notice though.
    The Tremor at AIR
    Member tazinhawaii's Avatar
    Apr 2006
    Default outside min and max values
    I had the same question once. It's covered in the manual somewhere. It means the value that it's trying to update would fall outside your max and min values located in the RCTAS window. For example, let's say yoou're doing the VE table and the max and min are 20 and 100. If the RR is trying to update that value to less than 20, the border will turn red and no update will take place.
    Derrick
    1969 Camaro, LS3, 4L80E, Dana 60 rear, Air Ride, 19 and 20" wheels, Baer Brakes, and a lot more.
    2008 Charger SRT-8 Super Bee, Exhaust and Cold Air kit (Wife's car)
    2007 Yukon XL Denali, Family Hauler
    http://s330.photobucket.com/albums/l...i/69%20Camaro/
    Nov 2006
    Quote Originally Posted by tazinhawaii View Post
    Derrick
    where exactly did you see this?
    red or blue border i get updates no matter what, up and down.
    Jan 2007
    Normally the border around the VE table is blue whilst updating but, and I think Derrick is correct...when your settings are out of range it turns red instead of blue.
    Howard
    DUCT TAPE.
