If you put the same numbers in both tables will the computer still monitor spark knock?
I beleive that if it did register knock that since both tables are the same the computer will not pull timing, is this correct? And will it still record knock?
The reason I'm asking is that at the track when I get on the T-brake and 2-Step the computer registered knock and it pulled timing for the entire run even though it stopped registering knock after that point. I do not want this to happen yet I still want it to record if there's any knock.
Lee
