Results 1 to 3 of 3
Thread: can .tun files get corrupted?
    Lifetime Member Aloicious's Avatar
    Nov 2007
    Default can .tun files get corrupted?
    so I'm getting ready to do a flash and I pull up my tune I've been working on and it gives me an out of range error for the cranking VE table....well the range according to efilive is 0-10 and my values are all the same around 2.1, no red boxes, I even lowered it back to stock which was all about 1.8, and refreshed but it still gave me an out of range error....so I ended up pulling up an old tune and re-creating the changes and re-doing the .tun file for the flash, got done, saved it under a different file name, no error. flashed the new file, everything works fine.
    I'm guessing it was just the data in the file that got corrupted somehow, anyone ever ran into this? what would cause this? laptop is clean, no problems or viruses or anything of the sort when I scanned it, I only use it for tuning.
    strange.
    1996 c1500 gen1e 5.7L - the "LS31", 24x CNP, LS2 coils, modified T56, 12200411PCM running COS3, zz4 cam, custom MPFI, etc. coming soon: Twin Turbos
    It can happen on older versions of the software. I can't recall the exact procedure but it had to do with changing the VE units in between editing and saving the data. It is fixed in the latest release (V7.5.4 build 64).
    Nov 2007
    thanks Paul, I actually saw the updated version after it happened and installed it.
  1. corrupted data/tune
    By limited cv8r in forum RoadRunner Real-Time PCM Emulator
    Last Post: June 11th, 2010, 03:42 AM
  2. T42 / T43 DVT files
    By GMPX in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 5th, 2009, 03:03 PM
  3. OS files
    By DaddySS in forum Custom Operating Systems
    Last Post: January 23rd, 2007, 02:27 PM
