Page 14 of 19 FirstFirst ... 41213141516 ... LastLast
Results 131 to 140 of 182
Thread: BBL installer update: June 22, 2008
  1. #131
    Feb 2008
    You can add the external PIDs that you want/need to log by editing the Options.ini file and then copying it into the [Scan] tab page.
    OR
    You can edit the FlashSCan setup options:
    A/D PIDs: set to Yes to automatically include all external PIDs in ALL logs.
    Ser PIDs: set to Yes to automatically include all serial wide band PIDs in ALL logs.
    If those settings are set to No, then only the external ans serial PIDs listed in Options.ini will be logged.
    Thanks Blacky,
    I have tried editing the options in the V2 to say yes to those options, when it was pluged into the laptop. But i could not get it to open anything to let me selct yes or no... Does it need to be actually pluged into the PCM.. ??
    I ate my bowl of Aussie rice for dessert, Main course was imported rice...
  2. #132
    Quote Originally Posted by vxleather View Post
    Thanks Blacky,
    When the option is highlighted, use the left/right arrow keys to change the value. Then press Ok to save the changes.
    After changing either of those two settings, you need to use the "Select PIDs" option again to reload the PIDs which will take those two settings into account.
  3. #133
    Feb 2008
    ok thanks will give it a try tonight... thanks for all the advice .
  4. #134
    Jul 2003
    As a suggestion... Give the ability to the program to add calc pids w/o using txt editor...
  5. #135
    That is very high on the priority list for version 8
  6. #136
    Lifetime Member Kevin Doe's Avatar
    Aug 2007
    Maybe I'm out of the loop here, but can you have calc pids displayed on the FlashScan unit itself? I am trying to check instant MPG at different driving conditions, and it would be really nice to check them real time as opposed to downloading the log and looking at it on the laptop.
  7. #137
    Jan 2005
    Somewhere in this forum I believe Paul indicated V2 will only support a limited set of CALC_PID's (i.e. BEN factors). We would need to add the respective CALC_PID's to the log file after uploading them to the PC after the fact.
  8. #138
    May 2007
    just finished testing and I am pleased to say that my v2 is now working great with my lm1 wideband in bbl.
    Now if I can fix my issue with the wideband itself I will be doing some ve tuning.
    My wideband works but when I go wide open throttle or close to it, my wideband trips out and say's sensor timing error. I think I need to put the copper heat disapater on the o2.
    2000 NBM trans am.
    427 Dart ship block,Lme ported Ls7 heads 12.5 compression
    246/262 .730/.712 112+4 low lash solid roller
    Rmvb 4l80 with transbrake, 8" FTI converter
    12 bolt Moser rear end with 4.10 gears
  9. #139
    Default replace the sensor....
    Quote Originally Posted by Aint Skeered View Post
    When you see the 08 error for sensor timing, it means the sensor heater is dying....(as per innovate tech line)
    Ouch...they cost.
    Chuck CoW
  10. #140
    Paul,
    Remember to add any new keys in the quick reference pdf.
    Joe
  1. BBL installer update: June 12, 2008
    Last Post: June 22nd, 2008, 07:57 AM
  2. BBL installer update: June 12, 2008
    By Chevy366 in forum FlashScan V2 BB Logging
    Last Post: June 13th, 2008, 10:37 AM
  3. June V2 update
    By jfpilla in forum E37, E38 & E67 PFI ECM's
    Last Post: August 13th, 2007, 11:09 AM
  4. Minor typo in the June 13th update
    By leres in forum E37, E38 & E67 PFI ECM's
    Last Post: June 14th, 2007, 05:27 PM
