Results 1 to 10 of 11
Thread: Fan settings E38
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    Question Fan settings E38
    Is there a way to set the fans lower on the E38 to something below the 192 shown on the table? Table G0901
    Elmer
    2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
    Oct 2005
    Did you do the fan patch? Then you can.
    You might need to have efiv2 plugged in to enable the feature I cant remember.
    But there is a patch to lower the temps in the table.
    2014 VF SV LS3 Maloo.
    Apr 2004
    searching for fan patch
    thanks
    Apr 2004
    I must not be in the circle for this. I guess I wait until it is part of the auto update process.
    The Fan patches have been out for sometime, but we are hearing from people that in the latest version they are not displaying correctly.
    You can find the patch within the Folder "Operating System Patches".
    Redline Motorsports
    Guest
    OK. Maybe this explains why on two cars this last week it didn't work. Using the latest sofware. Now what?
    Howard
    Member JAY4SPEED's Avatar
    Mar 2007
    I've had the same issue this week with the E38. I set B9904 to applied, performed a full reflash, reread the tune back out and I still have 192 as the min fan setting. Did I miss a step? I rechecked B9904 and it is still applied.
    Jay
    Lifetime Member izaks's Avatar
    Aug 2003
    There is a problem with the fan patch from build 64 on.
    Paul and Ross are aware of the problem
    2011 VE SSV 419 + CAM + Whipple 2.9FF SC + PPV front struts + Bilstein rear shocks + 6L90E with single piece carbon fiber prop
    Redline Motorsports
    Guest
    Is this a difficult issue to fix?
    Apr 2004
    Can the activation of these "patches" be made to be part of the auto update process? Having to add patches to update the software seems a little bohemian to me.
    Elmer
  1. DFCO settings
    By harascho in forum Tuning For Economy
    Last Post: March 11th, 2011, 05:07 PM
  2. Confused on IFR settings
    Last Post: June 17th, 2009, 03:47 AM
  3. Injector settings?
    By Aloicious in forum Gen III V8 Specific
    Last Post: April 14th, 2008, 03:54 PM
  4. Need help with IAC settings
    By SV8346 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 1st, 2008, 08:55 PM
  5. PE vs RPM settings
    By ahall1 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 12th, 2005, 12:28 AM
