Thread: Missing PID GM.DYNCYLAIR_DMA
    Default Missing PID GM.DYNCYLAIR_DMA
    Hello guys it's me again just trying to link my scantool to my high {B5101} High Octane spark Table so I can read a log to adjust the timing. Problem being the RPM tracks ok while reading the log but the load is way off at full load all the time. Seems I'm not able to find the PID GM.DYNCYLAIR_DMA.
    I guess I need to know if I must reconfigure the PID or write one?
    Thanks, John
    ps. I'm almost in heaven with my newfound second gear churping-tire shredding 5.3 Volvo!
    John,
    Connect to PCM and do Validate PIDs...
    then on the PIDs tab, uncheck Supported...
    then click on the Caption or Parameter column heading to sort alphabetically by that column, then just scroll down till you see it.
    Will Do and thanks,
    John
    Mar 2005
    I have this problem with an E40 PCM as well. after a validate with supported unchecked I see it there but it has a cross in it. How do you make it so it is supported and therfore link to the Spark map....
    or do just edit the cal_lnk.txt file and add say the GM.APCYL_E40_DMA WHICH IS SUPPORTED and throw that in the front of the link file.....
    Mike
    "Just a tune > yeah right !!!! "
    Mike,
    Whenever I update to a new version seems I have to reconfigure the cal-link file for B5101-B5111.
    I just copy and paste this: ,GM.APCYL_E40_DMA to those links and all is well again.
    I know Ross loves us E40 guys, he just doesn't like us!
    If you get it right though you can do this with your ride: http://www.youtube.com/watch?v=II7PmaKv_XU
    Good luck! John
    Default I've been having problems with E40s..........
    Hey Guys......I've been having problems with E40s..........
    I mostly tune vettes, but there are 2 huge problems....
    1) when using the same KR maps in the scantool for just about every other platform the map reads zeros and when there is KR it shows the correct value.... Problem is, with some 05 E40 corvette os's it works while using other os's it dosen't....... Srtangely, I get #'s like random timing values....??????
    2) second problem...When tuning E40's in 05 Vettes....When the A/C is on....there is either a torque system swing in the timing or the throttle is randomly moving about while you drive and on occasion after coming to a stop. the idle jumps up unexpectedly which is quite scary and unsafe.
    Anyone have similar problems...I never hear anyone complain about it, but....I also tune tons of 05 Corvettes.....
    Any similar experiences???
    Chuck CoW
  1. can someone tell me what I'm missing here?
    By 0rion in forum General
    Last Post: March 30th, 2010, 01:47 PM
  2. GM.DYNCYLAIR_DMA help.
    By joik307 in forum Gen III V8 Specific
    Last Post: August 13th, 2009, 12:16 PM
  3. E38 Missing tables? Or I'm missing something?
    By gmtech16450yz in forum E37, E38 & E67 PFI ECM's
    Last Post: January 7th, 2009, 03:28 PM
  4. DYNCYLAIR_DMA never above 0.50 grams/cyl?
    By S10Wildside in forum General
    Last Post: September 7th, 2008, 09:22 AM
  5. DYNCYLAIR_DMA reading low on boosted application
    By KAZ MotorSports in forum Gen III V8 Specific
    Last Post: June 5th, 2008, 08:58 AM
