Results 1 to 8 of 8
Thread: LS1 engine on another car
    Apr 2008
    Default LS1 engine on another car
    What steeps need to be done in case a LS1 engine is installed on another car like ford, Nissan? The case I have here is that, a friend has 94 ZX, he put LS1 engine and has removed the un-necessary plugs, but the engine doesn't start, some one said you need to cancel the security of the PCM, then every thing will be okay, can some explain this, please
    Regards,
    Odd Boy
    Oct 2006
    Set G0102 to none. What happens is without the correct signal from the BCM the vehicle will not be able to start.
    The Tremor at AIR
    Lifetime Member johnv's Avatar
    Jan 2005
    Even if the VATs is still on , the engine should still fire and run for a few seconds then stop, so maybe he has other wireing or setup issues
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
    Jan 2007
    Quote Originally Posted by johnv View Post
    Correct. We had this issue after the LS1 PCM upgrade. Vats needed to be disabled but the truck still fires...just dies immediately.
    Check wiring and codes.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Apr 2008
    I will check and get back to u
    Regards,
    Odd Boy
    Apr 2008
    Quote Originally Posted by 5.7ute View Post
    u mean {G1201} Anti Theft Configuration
    Regards,
    Odd Boy
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Quote Originally Posted by odd boy View Post
    Yes, you are right. Set that to "none"
    Dave.
    Apr 2008
    thanks guys
    Regards,
    Odd Boy
  1. LS1 Engine Oil Pressure- HTF do i log it?
    By Tre-Cool in forum General
    Last Post: September 29th, 2008, 01:41 PM
  2. LBZ on an Engine Dyno
    By thetallengineer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 25th, 2008, 04:32 AM
  3. what engine is this???
    By newguy2diesel in forum General (Petrol, Gas, Ethanol)
    Last Post: March 13th, 2008, 08:14 AM
  4. Engine won't run longer than 1 sec
    Last Post: March 28th, 2007, 12:57 AM
