Results 1 to 10 of 10
Thread: IAT Sensor when MAF bypassed
    May 2006
    Question IAT Sensor when MAF bypassed
    I am following the tutorial for VE tuning and am at the spot where it says to check the forum.
    When I unlug the 5 pin MAF from my 2002 vette for data logging how do I incorporiate IAT readings.
    Thanks from a real newbie trying.
    Nov 2006
    i have the 3 pin MAF,
    and i don`t bother unplugging it.
    it doesn`t make sense if you configure things right. IMO
    raise the RPM Threshold For Airflow Calculation {B0120} to the maximum.
    if you really want to, you could unplug one of the signal wires.
Name:	5 Wire MAF Pin Out.jpg
    Using a pick tool, you can extract the terminal for pin E... the PCM will see open circuit for the MAF signal and should throw DTC P0102.
    Carefully tape up the terminal so it doesn't get dirty/damaged.
    May 2006
    Thanks a bunch. Terminal E is now unplugged.
    Oct 2005
    With this method misfire detection would still function?
    Quote Originally Posted by voda1 View Post
    No... any MAF codes cause misfire detection to be disabled.
    Oct 2005
    "raise the RPM Threshold For Airflow Calculation {B0120} to the maximum."
    Why would that cause a MAF code?
    Jan 2005
    This step is actually precautionary to ensure a MAF failure code. As Mr. Prick point out, if the tune is setup correctly, it should not be necessary to unplug the MAF. And as Joe pointed out, pulling the pin will have the same effect as unpluggin the MAF.
    $0.02: I don't necessarily agree with the validity of the B0120 statement either. By raising this value to the upper limit, the PCM will always attempt to use a hybrid of the VE and MAF values. Going to the lower limit would bypass VE values.
    I agree with TAQ... raising B0120 to max does not give exclusive VE operation.
    Raising B0120 does not cause a MAF code.
    Nov 2006
    no it does`nt,
    it keeps the MAF from being the sole source of airflow
    if engine speed is above this value.
    i should have added that i also have the MAF table zeroed and,
    have no ill affects with it still plugged in.
    the combination of all these things keeps the MAF from being a factor,
    or at least that is that is how i am doing it.
  1. TP sensor
    By Slowrc in forum Gen III V8 Specific
    Last Post: January 29th, 2009, 06:24 AM
  2. TPS sensor?
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: December 10th, 2007, 01:28 PM
  3. Anyone know of a 1.5 bar MAP sensor?
    By mistermike in forum General (Petrol, Gas, Ethanol)
    Last Post: August 19th, 2007, 08:57 PM
  4. IAT sensor
    By Chevy366 in forum Lounge
    Last Post: August 3rd, 2007, 11:49 AM
  5. 2 Bar MAP Sensor
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: October 11th, 2005, 12:28 AM
