Results 1 to 5 of 5
Thread: 2007 Cobalt SS Operating System patch and VE ?
    Junior Member yellowC6ohio's Avatar
    Oct 2007
    Default 2007 Cobalt SS Operating System patch and VE ?
    I was looking over a 2007 Cobalt SS tune file and i found this
    Operating system patch
    This patch will extend the VE table range up to 255kPa (21PSI).
    ok well 255kPa = 36.9psi
    so i just thought the conversion was wrong but then i remembered something from my EVO tuning software. it's tuned using engine load, and boost cut just so happens to kick in at 255 which is 21-22PSI.
    my question is what is correct and if the 255 refers to engine load is that what we should be using in our MAPs instead of kPa.
Name:	cobalt efilive 1 small.JPG
Name:	cobalt efilive 2.JPG
    or is there a table missing or am i just crazy
    Ah, well, pretend you never saw that, it was not supposed to be released yet. You will need additional .calz files to view the different VE correctly. I will post those shortly.
    Oct 2007
    here is the difference in LTFT between kPa and LOAD
ID:	3732   Click image for larger version.
    Just to clear this up. Sorry, but I am going to talk metric here.
    100kPa = atmosphere (assume sea level etc).
    100kPa to 255kPa is boost. Max of 155kPa (22psi).
    Oct 2007
    lol, thats what i get for posting before thinking..
    THANKS
  1. 09 lmm operating system
    By 07.5duramax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 11th, 2009, 12:59 PM
  2. 02 operating system?
    By THEFERMANATOR in forum Allison 5 & 6 Speed
    Last Post: October 25th, 2009, 12:58 PM
  3. Mafless TC Off after Operating System Patch?
    By Acer in forum Gen IV V8 Specific
    Last Post: August 14th, 2007, 12:52 AM
  4. operating system
    By ls1transam346 in forum Gen III V8 Specific
    Last Post: February 22nd, 2007, 11:49 AM
  5. Operating System Survey for 2007
    By emarkay in forum Lounge
    Last Post: January 19th, 2007, 07:30 AM
