Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 67
Thread: is lean cruise bad for the engine
  1. #21
    EFILive Reseller kbracing96's Avatar
    Sep 2005
    I got it to DL, but not quite sure what to do with it... Does it just go in the EFILive calibration folder, or in the tune it's self?? And will it only work on the Camaros and Vettes, or should it work on the trucks too?
    Cax extentions for EFILive tuning software to allow you to activate lean cruise on US based camaros/corvettes.
    Just dump these files into your calibrations folder in the lsb folder. Look for the new tables to show up and then do a full flash of the file after making the change, then all tables will be used.
    Be warned. THESE ARE FOR TESTING ONLY. Do not damage my air.
    EDIT: It won't let me attach it's cuz it a TORRET file and I have not converted it... I can email it.
  2. #22
    Sep 2005
    Does this work?
  3. #23
    Oct 2006
    I think all you have there is the TORRENT start script , used to start the TORRENT file download , the file is 23.3kb in size , that file is 375b .
    Still when I try to download it stalls or says "stalled" and just sits there , tried 2 different Torrent programs .
    2006 Trailblazer
  4. #24
    Jul 2003
    someone please upload this to rapidshare.
  5. #25
    Jul 2003
    I got it to download but it doesn't work.. files are CAX Format.
  6. #26
    Oct 2006
    Can you post it here ?
    It sucks , the EPA would force a gas saving setting to be restricted , especially now when gas is so high in cost .
    2006 Trailblazer
  7. #27
    Jul 2005
  8. #28
    Ok, now what do I do with the .cax files...?
  9. #29
    Jul 2005
    Default How to use it
    There is a readme file inside the zip, it says.
    Extract this zip in to :\Program Files\EFILive\V7.5\Calibrations
    When you next load a tune file you will see a option at the bottom of the engine segment, look for parameter B9000.
    I never found B9000 but there is a new entry at the bottom of the engine segment, exactly as stated, called 'bad things inside'. This contains an option enable/disable lean cruise. It also states that all the maps and parameters also need to be set up as per the Holden calibrations and then you you do a full flash. Then if it works.
    All the Holden info is available at Holdencrazy.
    Good luck, Steve
    Just got off the showroom floor, now lets fix it.
  10. #30
    Sep 2005
    Quote Originally Posted by vzsv8 View Post
    Good luck, Steve
    That seems to work as it shows up in the stock tunes I looked in, but it's not in the CO's like I am running, Will have to find some thing to try it on.
  1. Lean cruise tip-in
    By LinearX in forum Tuning For Economy
    Last Post: February 28th, 2010, 02:52 AM
  2. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 01:44 PM
  3. Lean cruise on 04 GTO
    By 98ls1blackbird in forum General (Petrol, Gas, Ethanol)
    Last Post: August 26th, 2007, 02:11 PM
  4. Lean Cruise and Cruise Control
    By neil in forum Tuning For Economy
    Last Post: July 9th, 2007, 09:42 PM
  5. Lean Cruise - US - LQ4 6.0L - Anyone done it?
    By Zfreak in forum General (Petrol, Gas, Ethanol)
    Last Post: January 18th, 2007, 11:58 AM
