Results 11 to 20 of 21
Thread: FAST DUAL O2's
    Nov 2006
    calc_pids(fast).txt
    i found this somewhere around here.
    i think it is for the High Res Mode:
    This provides a 0 - 4.096 volt output signal.
    there is also a Simple Mode: (serial?)
    This takes the output voltage and multiplies it by 10
    to calculate the actual air/fuel ratio.
    Member VT LS1 NZ's Avatar
    Quote Originally Posted by 427 View Post
    i have a fast without the rpm kit- it works a great-
    but i have a b/new fast dual w/band with the rpm kit coming in a week or so what would u like to know-?
    Nick--
    I like to know if your RPM's are accurate and stable.
    I could not catibrate mine accurately with the calibration settings offered and found they weren't stable.
    856RWHP 408 Supercharged LS1 Holden Commodore.
    Jan 2005
    If the FAST dual 02 module has an electronic copy of the install manual, would someone mind emailing it to me? TAQuickness at comcast dot net. I'm having a booger of a time trying to find it on their website. - Thanks
    Mar 2008
    Drag Racer Here! Questions might be nieve but the GM PCM takes its input from the primary 02's (right ?), I also run a FAST and it gets its input from the "secondary" 02's (right ?) which I put in the old Stock post Cat location. (I run NO Cats) So the injectors get their "Marching Orders" from the primary 02's ONLY (right ?)
    My V2 records (and plays back through my computer and Custom Dashboard) the voltages from the primary 02's, and the FAST records (and plays back on its own screen) the AFR readings from the secondary 02's. I look at them both for tuning decisions!
    Why is it beneficial to feed the FAST info into the V2 so I can only look at the secondary 02 info which does not impact my PCM (injectors) during the run? I understand that the FAST is not tied to RPM but it is obvious when I am WOT.
    What is gained by not "seeing" the voltages from the primary 02"s?
    (I was getting reved-up to feed my FAST into my V2 but I'm not so sure as I "think it through")
    A Confused Drag Racer!
    JR
    JR,
    The FAST is reading the wideband sensor which you located in the secondary O2 location (no cats), right...?
    The FAST wideband is measuring the actual AFR;
    You want to be able to match up the FAST wideband AFR signal with RPM, TPS, MAP, ECT, timing, etc, so you can correlate how the AFR changes in response to other engine parameters...
    and this also allows you to create a map of AFR (or BEN) vs RPM vs MAP for use during AutoVE or for you to view in a more concise manner (compare to a log chart).
    Joe
    Member 427's Avatar
    Dec 2007
    Smile
    Quote Originally Posted by VT LS1 NZ View Post
    well if u can wait till i get mine i will be more then happy to share notes-
    i know for a fact that the fast machine is very accurate-vs some of the so called best afr systems on the market--
    i can comment on the rpm stuff just yet but i have 2 friends with it and they say they have never had a problem with reading the rpm vs afr and its been dead on and stable-
    427
    Mar 2008
    Maybe off point - Maybe not?
    Have any of you guys run (at the dragstrip) your BLOWER cars WITHOUT an
    air filter. If so, what did that do to your AFR settings. My 9 sec C5 is a bit sluggish in 3rd gear (from 1/8 mi. to 1320') and builds quite a bit of AIT in that portion of the run. Tuner thinks the airfilter is restricting air flow in 3rd gear and wants me to run without one!!!
    JR
    (Thanks for any input)
  9. #19
    Member 427's Avatar
    Dec 2007
    Smile
    Quote Originally Posted by JR-CRUZN-C5 View Post
    JR
    interesting-
    i am getting the same feedback-
    i am trying a new airbox system as my one is too restricting-
    i done some testing to find out that i am short 10-15 hp when running the air filter-
    my air filter set-up is over the the radiator
    mine is n/a by the way-
    427
  10. #20
    Mar 2008
    My setup is also "over the radiator" and because of my aftercooler size I am limited to the size of the air filter as a result. I am running an "offset" air filter from A & A out of California. I am making about 1,000 HP so the air filter is probably not very good for my setup down track!
    JR
  1. Dual Fast Wideband
    Last Post: February 18th, 2010, 04:37 PM
  2. FAST dual WB to EFI V1
    By rickou812 in forum External A/D inputs
    Last Post: November 19th, 2009, 09:06 AM
  3. need help installing fast dual wideband
    By red83 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 19th, 2008, 07:01 AM
  4. Anyone try the FAST dual wideband setup?.................
    By FreddyG in forum General (Petrol, Gas, Ethanol)
    Last Post: December 23rd, 2007, 05:08 PM
  5. dual fast 90 set up
    Last Post: June 7th, 2006, 01:52 PM
