I've been trying to log MAF readings with my V2 (Boot 2.5.08, Firmware 2.5.20) in Grams/Sec., but I keep getting Lbs/Min. when I look at the Data in the Scan Tool.
I thought it was this line in the 'Options.ini' file:
PCM,MAF, AirFlow, 1, lb/m, /, 7.559873,
that was converting it, so I removed it from the file, downloaded the new file to the V2.
When I looked at the data in the V2 while logging it was Gram/Sec., but when I remove the log from the V2 and looked at it with the Scan Tool (Build 67), it shows Lbs/Min.
Am I doing something wrong or is there are problem with the units in Scan Tool?![]()
