Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Weird VIN
    Sep 2007
    That Icon is not available, just the read Icon, and the cal only flash buttons are available. Also I am just curious, as to why Tis wiped out the serial number.
    01 CCSB Chevy 4WD HD LB7, built trans, and some other stuff
    x2 mine was minus its serial after the new ecm from the squeeler.
    04 LB7
    2010 LMM
    2015 LML
    Quote Originally Posted by rgullett83 View Post
    That might be because your registration details are not entered correctly, try restarting the software with the V2 plugged in to the USB port before you run the software.
    Sep 2007
    Ok I will try that.
    Thanks!
  1. Weird fan problem
    By johnsZ06 in forum E37, E38 & E67 PFI ECM's
    Last Post: December 25th, 2008, 02:20 PM
  2. Weird AFR at idle
    By 5.7ute in forum Custom Operating Systems
    Last Post: December 7th, 2006, 12:04 PM
  3. Weird bug
    Last Post: September 27th, 2006, 09:42 AM
