ok, will do here in a short bit, gotta finish some stuff....
Tomorrow is T&T at Byron for the big Olds meet on Sunday. I am planning on going, hopefully both days.... Feel like coming out?
i tried using various bench harness setups based on this pinout (J1 blue connector) to reflash the simens box with TIS and it isn't working right. after it finishes it keeps restarting. anyone bench flashed the siemens box successfully? what bench harness setup? thanks...
-alex
what is your bench harness pinout?
Need to come up with an E67 adaptor harness and be done with those Siemens boxes![]()
heh. i couldn't care less about the siemens boxes, but someone asked for a replacement box flashed for his VIN. every other GM box with a blue 80 pin connector works with the same bench harness, but for some reason not this stupid [expletive] box...
