Results 11 to 20 of 24
Thread: has anyone played with shift timing?
    Jan 2007
    Ok thanks for the help. I just though you might be able to disable it earlier in the rpm range or disable it all together to get more pressure?
    Sorry for all th questions but is there any benifit to adjust any of the other TCC tables or trans tables besides shift points?
    There may be if you know what you're doing (which I don't); If you tinker with shift timing tables and such, you run the risk of seriously screwing something up (potentially "pick the pieces of your transmission up off the ground" type screwed up).
    Jan 2008
    I asked the shift timing ?? on duramaxtuner, here is Nick's reply;
    "It's a touchy area, you'll find a lot of mixed review on it.
    My personal truck has the shift times shorted between 150 and 200 ms from stock. I would work in 25-50ms incriments and be careful!
    Hope this helps,
    Nick"
    Jan 2008
    With respect to the TCC Solenoid >? I think another reason that it is pulsed is for the cooling effect.
    It allows a small amount of fluid to flow through the clutch during the off segment
    Jan 2007
    Ok thanks but does anyone else have trouble with their tcc lockup at WOT?
    I wish there was a way to log it but it dosent feel like my converter locks untill about 50-60mhp?
    Jan 2008
    I think u'r correct, that there is no PID's or logging for the trans.
    However....you can tune the TCC lock-up speed to where you'd prefer it.
    Upload the stock trans tune & check the TCC lock-up speed D5014, change it & see what it does & how you like it.
    My stock tune in 6th gear wants lock-up at;
    50% TPS=74kph , 75%+=85khp (55mph)
    does this help??
    Senior Member Racehemi's Avatar
    Nov 2005
    Here are the Allison PID's I have logged
Name:	Allison PID's.png
    04 2500, LLY/A, 4x4, CC, SB, 285 Toyo's, Amsoil lubes, Access Roll-up Tonneau, ATS Stage 2 trans, ATS 5 Star Converter, Bilstein's, Caltracs bars, Cognito Braces, EFILive, Kennedy Diesel Custom Tuning, Kennedy Diesel headlight harness, Kennedy Dual Lift Pump/Filter combo, Prodigy brake controller, Spa DG 211, Trippin Cyclops overhead gauge mount, , TTS 4" Exhaust, TTS Xtreme Beta, Amsoil Ea filters, Banks CAI
    Jan 2008
    I have a 2008 with the 6spd Ally, I see the PID's that you have logged when "all" is selected. but when I Tag only the "supported" PID's the list goes to zero. This tells me that the new 6spd TCM isn't monitored. I could be wrong.....
  9. #19
    Jan 2007
    I did not even know you could log PID's from the allison. My labtop broke so I can't check it now but next time ill see when I connect to the tcm see if i can try to validate the PID's. I havent messed with my part throttle lockup I just set the WOT values in each gear to what they were in each gear in T/H.
    For thoes with a stock converter and trans what slip are you seeing with higher power tunes?
  10. #20
    Jul 2007
    Quote Originally Posted by sledbert View Post
    You can only log one controller at a time. Do you have the allison lbz/lmm controller selected?
  1. Billet LT1 Timing Cover - Clears Double Row Timing Chain
    Last Post: November 17th, 2009, 01:15 AM
  2. my box will only shift 1st and 2nd
    By trickas in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 3rd, 2009, 01:46 PM
  3. Anyone played with Spark dwell times?
    By Tordne in forum General (Petrol, Gas, Ethanol)
    Last Post: February 23rd, 2009, 02:59 PM
  4. why 1>2 shift happens at higher rpm than 2>3 shift?
    By 350SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 13th, 2008, 11:54 AM
  5. Disable adaptive shift learning after Shift Kit Install
    By BlackGMC in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2008, 05:49 AM
