Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Hmm, here are some other cax files...
    Oct 2005
    Default Hmm, here are some other cax files...
    2008 Z06 C6 Corvette
    Jan 2007
    Can't download those files Ringram.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Oct 2005
    Works for me..
    Included inline now..
    Jan 2007
    Says 'not authorized' to download the files. I guess you're a member of that site?
    Howard
    DUCT TAPE.
    Oct 2005
    Affirmative
    Lifetime Member Aloicious's Avatar
    Nov 2007
    hehe. nice. so if I understand this 'patch' correctly, setting it to 'enable' will simply make the lean cruize tables active and workable for all LSx controllers, not just holden ones?
    1996 c1500 gen1e 5.7L - the "LS31", 24x CNP, LS2 coils, modified T56, 12200411PCM running COS3, zz4 cam, custom MPFI, etc. coming soon: Twin Turbos
    Jan 2007
    I believe so....but it doesn't work with a COS...so it seems.
    Easier to command it in B3647 in that case.
    Howard
    DUCT TAPE.
    Nov 2007
    Quote Originally Posted by hquick View Post
    thats true, I may try it in 12212156 which is what I'm running.
    OT- howard, how does that 12208322 OS work with the L31+411?, I haven't seen much difference between it and 12212156? also, have you been running the Transient fuel .cax? if so, how's it working/any issues with it?
    Jan 2007
    08322 is the base for my tune.
    I haven't actually had a chance to implement the transient tables yet (load them into my PCM).
    Will be doing so as soon as I can get a little more info on how they work/are adjusted.
    Howard
    DUCT TAPE.
    Nov 2007
    yeah they look good, but their function is a little vague. trying to learn 'em though. if I can figure 'em out I'll switch over to 08322 and use them. I can't really find any difference between the 08322 and 12156.
  1. '09 E85 6.2L files ?
    By gmh308 in forum Gen IV V8 Specific
    Last Post: November 29th, 2008, 10:32 AM
  2. Where are the .dtc files...?
    By joecar in forum FlashScan V2 BB Logging
    Last Post: October 20th, 2008, 01:39 PM
  3. Where did all my files go?
    By Ira in forum FlashScan V2 BB Logging
    Last Post: December 5th, 2007, 05:24 PM
  4. MAP files help
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 14th, 2006, 12:33 PM
