http://www.ls1-australia.com/forum/v...p?f=105&t=4041
Link to attached file
http://www.ls1-australia.com/forum/d...ile.php?id=268
Please delete if not appropriate.
2014 VF SV LS3 Maloo.
Can't download those files Ringram.
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
Works for me..
Included inline now..
Says 'not authorized' to download the files. I guess you're a member of that site?
Howard
DUCT TAPE.
Affirmative
hehe. nice. so if I understand this 'patch' correctly, setting it to 'enable' will simply make the lean cruize tables active and workable for all LSx controllers, not just holden ones?
1996 c1500 gen1e 5.7L - the "LS31", 24x CNP, LS2 coils, modified T56, 12200411PCM running COS3, zz4 cam, custom MPFI, etc. coming soon: Twin Turbos
I believe so....but it doesn't work with a COS...so it seems.
Easier to command it in B3647 in that case.
Howard
DUCT TAPE.
thats true, I may try it in 12212156 which is what I'm running.
OT- howard, how does that 12208322 OS work with the L31+411?, I haven't seen much difference between it and 12212156? also, have you been running the Transient fuel .cax? if so, how's it working/any issues with it?
08322 is the base for my tune.
I haven't actually had a chance to implement the transient tables yet (load them into my PCM).
Will be doing so as soon as I can get a little more info on how they work/are adjusted.
Howard
DUCT TAPE.
