Here is my calc pid file for idle tuning. with this file and a map you should be able to dial your idle in to a tea on the first try from a cold start to operating temps.
The correction is directly applied to the Airflow idle table for both PN/in gear and ac on and off. To use these pids with a map set either a row/colum to rpm =8000 and use the respective ECT values to build your tables. Happy idle tuning
Code:# ============================================================================== # File details # ------------ # # This section defines various details about the file format. *FILE #Parameter Value Description #---------- ---------------- --------------------------------------------------- VERSION 7.1.1 File version DECSEP . Decimal separator used in this file # ============================================================================== # Units # ------------------- # See sae_generic.txt for more information on the *UNITS section *UNITS #Code System Abbr Description #-------- ---------- -------- ------------------------------------------------------------- *CLC-00-000 gps -32.0 32.0 2 "{GM.IAC_LTDAC_DMA} + {GM.IAC_STD_DMA}" *CLC-00-001 gps -32.0 32.0 2 "{GM.IAC_LTD_DMA} + {GM.IAC_STDAC_DMA}" *CLC-00-002 gps -32.0 32.0 2 "{GM.IAC_LTPNAC_DMA} + {GM.IAC_STPN_DMA}" *CLC-00-003 gps -32.0 32.0 2 "{GM.IAC_LTPN_DMA} + {GM.IAC_STPNAC_DMA}" # ============================================================================== # Add slot definitions here # -------------------------------- # See sae_generic.txt for more information on "SLOT" formats # #Units Low High Fmt Expression #------------ ------------- ------------- ---- -------------------------------------------------------------- # ============================================================================== *PRN - Parameter Reference Numbers # -------------------------------- # See sae_generic.txt for more information on the *PRN section # #Code PRN SLOT Units System Description #------------------------- ---- ------------ ---------------- ---------------- ------------------------------------------ CALC.RAFIG F600 CLC-00-000 "gps" CALC "Idle Airflow Correction AC off, in gear" CALC.RAFACIG F601 CLC-00-001 "gps" CALC "Idle Airflow Correction AC on, in gear" CALC.RAFACPN F602 CLC-00-002 "gps" CALC "Idle Airflow Correction AC on, P/N" CALC.RAFPN F603 CLC-00-003 "gps" CALC "Idle Airflow Correction AC off, P/N"
