1SH, did the 12212156 file work out (does your 'Hoe run...?)...?
It did! I drove it home today. I even did a little brake stalling and tire burning to ensure proper operation
EDIT: Actually I had to find the same OS. The 12212156 OS didnt work.
Driving a truck with a BLOWN engine has two meanings. I get to experience BOTH on a regular basis
2006 GTO....in progress![]()
2002 6L/80E/Radix/ Tahoe
Cool... good job.
More info:
1787-gm-os-to-custom-os
13658-Why-does-1st-gear-slam-into-2nd-4L80E-translplant
What steps did you do...?
(edit: note to self: he started with 4L60E 12216125).
I took the tune from a 8.1L/4L80E, same OS as mine. 12216125
I opened it and my dyno tune, then just followed the steps in the segment copy directions. I copied the trans calibration and trans diagnostic segments into my dyno tune and loaded it in the PCM. I started up and ran great first try. It works wonders when you can find the same OS to copy from.
Thanks for helping me out![]()
what if you have OS 09381344?
this is the only missing link in my 4L80e conversion...
thanks!
forged LS1 I Patriot Stage III heads I Patrick G spec'd TR grind Comp Cam I ProCharger I High Tech Transmissions I Ultimate Converter Concepts I tuned by cablebandit (soon to be me) @ MSS I Exotic Exhaust & Fabrication custom exhaust
got the 4L80e segments for my OS...
was very easy to swap segments and seems to work fine...
If it's ok with you, can I eyeball your file......thanks.
here ya' go...
please look at it for the issue I posted in a couple other threads as well...
thanks!
ANY suggestions are greatly appreciated!
very new to tuning...
