Results 1 to 10 of 15
Thread: .cax file updates
    Arrow .cax file updates
    This thread contains the .cax file updates.
    They will have been checked and merged before hitting this thread.
    The cal_link.txt file will also be included.
    The title of each post will show the date of the update; the text of each post will say what the update contains.
    I will lock/unlock this thread as required.
    Default 9/28/2008 transient fuel base files
    These are the 4 transient fuel base files we're starting with.
    Default 10/02/2008 transient fuel base files with lean cruise merged
    These are the 4 transient fuel base files with lean cruise merged in.
    Note: there's no lean cruise .cax file to merge for 12225074.
    Each of the 4 files contains a comment listing which OS's the file supports;
    simply copy the file and rename using the OS name you require;
    e.g. "; Calibration definition extension for OS 12212156, 02020003, 02020005"
    means that 12212156.cax can be copied to 02020003.cax and 02020005.cax.
    Last edited by joecar; October 2nd, 2008 at 12:04 PM. Reason: Added 92111922/12593358. 92111922 now contains LC.
    Default 10/06/2008 TF+LC update
    These are the base OS's supported so far:
    • 12202088
    • 12208322
    • 12212156
    • 12221588
    • 12225074
    • 12593358
    • 92111922
    Each file contains a comment listing which OS's the file supports;
    simply copy the file and rename it to the OS name you require;
    Copy the .cax files for your OS's to the folder C:\Program Files\EFILive\V7.5\Calibrations.
    Open the tunetool, at the end of Engine Calibration you will see new subsections.
    Some parameters in some .cax files are commented out;
    these will be filled in when their details are discovered.
    Let me know if the text descriptions need more work.
    Last edited by joecar; October 18th, 2008 at 05:18 PM. Reason: Corrected address and enumeration for LC Enable for both 12221588 and 12593358.
    In post #4, updated the zip file -> Corrected address for LC Enable for 12221588.
    Thanks Marco, I appreciate your help......showthread.php?p=80783#post80783
    In post #4, I also corrected the enumeration for LC enable for 12221588.
    Can someone please check which of the following are the correct values...
    (in other words are the original 'Paranoid Android' values the correct ones...?
    Updated post #4: Corrected address and enumeration (back to original) for LC Enable for 12593358 also.
    Please check the following image.
    Default 10/20/2008 Update: Moved {B9100} to Fuel->Lean Cruise->Parameters
    Update: Moved {B9100} Lean Cruise Enable to Fuel->Lean Cruise->Parameters (Transient Fuel stays in the same place).
    - 12202088
    - 12208322
    - 12212156
    - 12225074
    - 12221588
    - 12593358
    - 92111922
    e.g. "; Calibration definition extension for OS 12212156, 0202000x"
    I re-updated the zip attachment to post #8... If you already got 2008-OCT-20, then please get it again.
    I updated the cal_link.txt file in post #8... I merged the links from 5.7ute(Mick) into the new cal_link.txt from build 71.
    This file goes here: C:\Program Files\EFILive\V7.5\Configuration.
  1. Updates and changes
    By eboggs_jkvl in forum FlashScan V2
    Last Post: October 15th, 2008, 10:48 PM
  2. Thanks for the updates.
    By mistermike in forum General (Petrol, Gas, Ethanol)
    Last Post: June 9th, 2005, 11:00 AM
  3. Updates?
    By Drake in forum General (Petrol, Gas, Ethanol)
    Last Post: June 20th, 2004, 09:08 AM
