Results 1 to 5 of 5
Thread: PID list in final Beta and RTM/RTW version?
    Aug 2007
    Default PID list in final Beta and RTM/RTW version?
    I was wondering, for the final (actual) Beta version, will the list of available PIDS be the same as it is now?
    Also, when the product is finally released, what is the plan for available PIDs? Will the V2 BBL'ing be identical to the Scan Tool on the PC? I thought this was discussed once, but I couldnt find the thread.
    Lastly, is it safe to assume that support for calculated PIDs will be in the final product as well?
    Thanks guys.
    2002 WS6, All-Lunati 383 Strok'r @11:1, Cartek Heads, Keith/Ross Racing Custom Cam, Victor Jr., 492whp 457wtq,
    Cartek Clutch, 9" Moser w/4.11's, 35 spline Detroit Locker, QA1's, NX, BMR, Tuned w/ EFILive V2 Black Box Logging
    Check Out My Latest Tune File: HERE
    The PID list for BB logging will have the same (if not more) PIDs than pass through logging.
    DMA PIDs will also be supported.
    CAlculated PIDs will not be supported. However, a few critical calculated PIDs will be preconfigured.
    Those will be:
    - Various wide band controllers.
    - BEN factors
    If anyone has any other absolutely necessary calc PIDs, we can add them into the BB logging firmware.
    Aug 2007
    Awesome. Thanks Paul.
    Keep up the good work. The V2 is turning into an outstanding tuning tool. I just look for reasons to drive my car so I can play with it.
    Senior Member Hyper99's Avatar
    Oct 2005
    Paul,
    Any guestimate on when we may have the calculated PIDS mentioned above. Everything seems to be working OK on the BBL and 7.5 stuff.
    I have logged 2.5 hours in passthough and 2.5 hours in standalone BBL and no hickups.
    (BTW - why does V7.5 report itself to the OS as V7??)
    99 Silverado 2500 Extracab Longbed
    33" BFG's - American Racing Rims
    Custom Dual Upper console gauge mount w/Autometer Sport Comp - Pyro, Oil Temp
    Autometer Sport Comp Boost/Vac in Custom Hypersonic Gauge Mount in dash
    LS-1 6.0L w/AFR 205cc Street Heads
    Vortech V2 blower
    42# Injectors
    Comp Cam - Custom Street Grind
    TTS Catback Exhaust
    Innovate LC-1 Wideband O2
    Tune and Trans mods via EFILive V1-V2
    May 2008
    Another bump for calculated PIDs via blackbox logging. Is this possible?
    I regularly use calculated PIDs to monitor the rotational speed of various components in the transmission based in trans input speed/trans output speed/current gear using if/then statements. Currently I can only do this with logged data, not live.
    Thanks in advance!
  1. BB Logging beta version is now available
    Last Post: November 30th, 2007, 09:14 PM
  2. Final Pre-Release version
    By GMPX in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2006, 01:04 PM
